FreeNAS-8.0.4-RELEASE-p2
J
jpaetzel
Guest
https://sourceforge.net/projects/freenas/files/FreeNAS-8.0.4/
This release addresses the recent Samba security advisory as well as a
security advisory in FreeBSD.
Release Notes for FreeNAS 8.0.4-RELEASE-p2
*** IMPORTANT ***
- The image size increased in 8.0.1-BETA3. The new size requires a 2 GB
storage device. The GUI upgrade can be used to upgrade a system from
BETA3, BETA4, or RC1 but upgrades from earlier releases can only be
done from the CD. The other option is to save the config, reinstall
the new version, then restore the config.
- FreeBSD can be really touchy with hardware. Please be sure to update
your BIOS/BMC firmware when upgrading / installing FreeNAS if you run
into OS hang issues. There have been cases identified where a BIOS
upgrade has fixed driver hangs, and/or other issues with FreeNAS; one
such example was with an Intel 82578DC motherboard, as noted in the
FreeNAS 8 forum thread titled "8.0.3-RELEASE coming soon..":
http://bit.ly/rq78Q3 , post # 70-88. Again, please only do this if you
experience booting / runtime issues, as some vendors don't test
FreeBSD interoperability as much as others between major firmware
releases.
- Previous builds were branded as i386/amd64 (32-bit and 64-bit
respectively). 8.0.3-RC1+ rebranded the architectures as x86 and x64,
respectively.
- 8.0.1 and 8.0.2 images advertised CIFS shares to Macs by default but
8.0.3 and later images don't advertise CIFS shares by default. If you
want to advertise CIFS shares in 8.0.3 and later, be sure to turn on
"Zeroconf" support in the CIFS global settings.
- Builds prior to 8.0.3-RELEASE with 'CIFS' didn't actually have AIO
(asynchronous I/O) enabled. So, if you experience performance
degradation after upgrading from prior versions of FreeNAS to
8.0.3-RELEASE or newer, turn off AIO or tune the AIO size from '1' to
something more reasonable (the new default in 8.0.3-RELEASE-p1 is 4096
or 4kB).
Changes since 8.0.4-RELEASE-p1:
Bugfixes
OS/Third party
1. Samba has been upgraded to 3.6.5 to address CVE-2012-2011 which is a
critical vulnerability. All FreeNAS users who are using CIFS are
urged to upgrade.
Changes since 8.0.4-RELEASE:
Enhancements
GUI
1. Selecting reboot now causes the screen to turn red during the
confirmation dialog, adding emphasis to the fact that this operation
will affect availability.
Bugfixes
OS/Third party
1. Samba has been upgraded to 3.6.4 to address CVE-2012-1182 which is a
urged to upgrade.
2. Create the ldap and nss secret files when LDAP integration is
enabled.
3. Ensure the configuration database is not world readable.
4. Remove failsafe from the PAM group file, this prevents a situation
where the wheel group being empty allowed any user to su to root.
Changes since 8.0.4-RC1:
Enhancements
GUI
1. Rename 'loaders' to 'tunables' to target the FreeBSD concept under
inspection (kernel tunables) (SF r10235, r10236).
Bugfixes
OS/Third party
1. Remove sane caps for minimum ZFS requirements for lower spec'ed home
user machines added in 8.0.4-BETA1. A better solution will be devised
in 8.2.0 with automatic system tuning, similar to legacy's
zfskerntune (SF r10271).
CIFS
1. Correct guest parameter setting in the GUI as it's a global option,
not a per-share option (SF r10296).
2. Allow Guest Only parameter only makes sense when Allow Guest is
specified (SF r10300).
3. Validate guest setting prior to accepting POST to ensure that the
value set for Guest is sane.
Changes since 8.0.4-BETA2:
Enhancements
Build
1. Remove Full_Install from the compressed disk image name to avoid
potential confusion when looking at the disk image vs the GUI
upgrade image (SF r10154).
Middleware
1. Do not restart collectd (reporting backend) when deleting snapshots
in the GUI (SF r10139).
Tools
1. Add arcstat.py and arc_summary.py tools originally contributed by
jhell (FreeBSD contributor), ported by jhixson to FreeNAS 8.x.
Bugfixes
GUI
1. Correct window title for snapshot deletion GUI (SF r10138).
Middleware
1. Catch ZFS snapshot errors when snapshots are done via the GUI
instead of failing silently (SF r10152).
2. Work around interoperability issues with user / group population in
the GUI by failing silently in certain cases if AD/LDAP users cannot
be retrieved (SF r10140).
3. Fix case where local and remote paths passed to rsync in Rsync tasks
weren't quoted, so paths with spaces in them would not work (FN
1285).
Changes since 8.0.4-BETA1:
Enhancements
OS/Third party
1. Update transmission to 2.42 (SF r10093).
2. Add MegaCLI tool (SF r10072, r10073).
3. Disable periodic tasks in the base system that would negatively
impact system performance on NAS boxes with large directory
structures (SF r10113).
Bugfixes
Middleware
1. Fix handling for 'every day' SMART tasks created in the GUI
(SF r10088).
2. Add in several robustness fixes to reduce potential for filesystem
corruption on root / boot device. In some scenarios this would also
improve performance when fetching data from the root device as well
(SF r10095, r10109, r10129).
CIFS
1. Fix vfs objects modules ordering so shadow copy (aka previous
versions) support functions again (FN 935, FN 1186, FN 1275).
2. Update samba to 3.6.3 to resolve several bugs (both security and
non-security related) (SF r10127).
iSCSI
1. Network field from iSCSI initiator could contain multiple IP
addresses, CIDR addresses, or ANY keyword (SF r10082).
2. Generate istgt.conf properly if and when multiple initiators were
specified (SF r10081).
Changes since 8.0.3-RELEASE-p1:
Enhancements
Build
1. Add .img suffix to simplify mounting full disk image for Windows and
OSX users (FN # 1236).
OS/Third party
1. Update firefly to 1696_6 for iTunes 10.5.2+ compatibility.
2. Add in sane caps for minimum ZFS requirements for lower spec'ed home
user machines.
AD/CIFS
1. Automatically create AD/LDAP user home directories (FN # 1203).
2. Add 'allow trusted domains' knob in the CIFS global configuration
(FN # 998).
iSCSI
1. Restrict portal input in the GUI to prevent scenarios where
incorrect input would prevent iSCSI from starting (FN # 1231).
Rsync
1. Add rsync+SSH functionality (FN # 990).
2. Add functionality to differentiate rsync pushing from pulling
(FN # 394).
Bugfixes
GUI
1. Fix disks / partition parsing when importing volumes (FN # 1202).
2. Restrict users from creating cronjobs / rsync tasks with long
usernames (FN # 1061).
Middleware
1. Correct smbpasswd parsing when debug level isn't set to minimum
logging (FN # 1224).
AD/CIFS
1. Escape samba AD/LDAP passwords (FN # 1225).
2. Ensure guest accounts are disabled if checked (SF r8276).
Changes since 8.0.3-RELEASE:
Enhancements
OS/Third party
1. Update ataidle from 2.6 to 2.72 based on maintainer's
(brucec@FreeBSD) recommendation due to interoperabilities with 2.6
and certain chipsets.
2. Fix the inadyn port so that it works on i386.
Bugfixes
Middleware
1. Fix a regression for DHCP users where /etc/resolv.conf would be
nulled out if DNS servers weren't specified in the GUI.
AD/CIFS
1. Disable AIO by default and change the default AIO read / write size
to 4kB. This was done provided feedback and the fact that the build
fixes actually enabled AIO, whereas prior releases didn't enable it
by default. This can cause issues with machines that don't have the
resources to service AIO requests quickly enough, where previously
they would be able to service requests at near line speeds, whereas
after they are unable to service requests that quickly.
NFS:
1. Add in logic to start lockd and mountd when NFS is enabled s.t.
FreeNAS doesn't need to be manually prodded to start the services,
or rebooted in order for the services to become effective.
Changes since 8.0.2-RELEASE:
Enhancements
OS/Third party
1. Use smaller block and frag sizes for /etc and /var .
2. Import a build tweak to nuke /var/db/pkg to save ~7MB space.
3. Other build tweaks to remove non-essential features and packages from
the image.
4. Disable output to /var/log/console.log in non-debug builds to avoid
unnecessary duplication in /var/log/messages .
5. Upgrade ataidle to 2.6.
6. Upgrade nut / net-snmp to 2.6.2 and 5.7.1, respectively.
7. Import omnibus build system fixes to fix the fact that the
8.0.3-BETA1 image was broken due to the environment of the build
machine where it was produced on. This also fixes other items, such
as DDNS because of build environment tainting.
8. Increase the /var md size from 74MB to 160MB s.t. samba will be able
to service requests copying large sets of files, and the rest of the
system will be able to play nicely with samba to a certain degree.
More tuning is required for larger samba userbases.
GUI
1. Add kernel tunable / sysctl support.
Middleware
1. Hide Etc/GMT* timezones as they're behavior is counterintuitive and
conflicts with Windows 7 semantics (see r8707).
AD/CIFS
1. Bump samba from 3.5.11 to 3.6.1.
2. Address simple failure cases with getting Kerberos tickets (clock
skew) and joining AD domains (invalid passwords, bad short domain
names, etc) so that users could better rectify improperly configured
NAS boxes; this means that if either of these cases fail, the GUI
will now inform the user that the 'Active Directory' service is
stopped.
3. Fix cachetool to better prevent potential race condition at boot
between winbindd and ix-cache.
4. Add knob for enabling/disabling Zeroconf/Bonjour (avahi) support in
the GUI. For technical reasons outside of the author's control, this
feature defaults to off when upgrading FreeNAS. FreeNAS admins
anticipating that they will have Mac users attempting to connect to
CIFS shares should enable this feature.
AFP
1. Bump netatalk to 2.2.1.
2. Add knob for controlling the maximum number of configurable
connections (see ticket: 847).
3. Only advertise services via avahi if they're enabled (see ticket:
852).
Rsync
- NFSv4 ACL support (see: r8375, r8414).
Bugfixes
OS/Third party
1. Fix NTFS volume imports.
GUI
1. ZFS volume deletion failed when trying to delete zvol with the name
'zvol'.
2. SSH pubkey saving was broken unless you manually add a newline to the
text box.
3. Fix traceback when trying to edit user if ssh public key was not
specified.
4. Fix the bug in rsync tasks where it would strip the trailing '/' off
the end of the destination path.
5. Fix a validation error when editing users / groups in 8.0.2+ where
if one entered in a path that wasn't valid, the GUI would traceback
instead of punting the actual validation error.
6. Fix an issue where if one entered in an invalid path, the GUI would
traceback instead of providing feedback stating that the directory
provided was invalid.
Middleware
1. Rsync task/crontab generation was broken with AD usernames and other
unsanitized input.
2. Fix email regressions since 8.0.2-RELEASE-p1 (SMART emails now work
with more than one recipient, non-SMTP authentication based emails
work again).
4. Fix an issue where if one autosnap process was killed uncleanly, more
autosnap processes could back up and eventually deadlock the system.
5. Fix an issue where the ZFS scrub cronjobs would execute every 30 days
instead of a number divisible by 7, so what would generally happen is
that ZFS scrubs would generally execute in the middle of the week.
6. Fix setting httpd to listen on an interface which is not the first
interface.
7. Add logic to create home directories on demand instead of failing
'silently' if the path to the directory didn't already exist.
8. Fix 'detaching' NTFS/UFS volumes so that it unmounts the volume in
the FreeBSD backend.
AD/CIFS
1. Change the default workgroup from FREENAS to WORKGROUP as having the
same name for the workgroup and the hostname is illegal per the
SMB/CIFS protocol.
Cosmetic items
1. Change "SSH key" in GUI to "SSH Public Key".
2. Fix GUI trademarks and branding to be more consistent with proper
branding, similar to what TrueNAS does today.
Major changes since 8.0.1-RELEASE:
- The email subsystem was not working correctly in 8.0.1-RELEASE, which
resulted in the system not being able to send mail, as well as of the
alerting system in the GUI.
Changes since 8.0.1-RELEASE:
- Allow decimal numbers for a dataset quota. (r8728)
- Fix setting recursive ACLs. (r8270)
- Start proftpd after ix-ssl to use the correct SSL cert. (r8246)
- Use wildcards in cron and rsync jobs instead of listing all values.
(r8214, r8211)
- Fix case in iSCSI targets to match the behavior specified by RFC
3722. (r8120)
Changes since 8.0-RELEASE:
There's too much to list here, but the high points are:
- Divorced the volume members in the database from the FreeBSD devices.
This resolves an issue where FreeBSD can change devices names and the
GUI doesn't pick up the updates due to the devices names being
hard-wired in the database.
- Support exporting ZFS zvols (virtual devices) as device extents via
iSCSI. 8.0 was only able to export physical device nodes or file
based extents.
- The GUI now has an event notification system.
- The email backend has been refactored.
- Many many changes in the GUI to help it validate and sanitize inputs
that are passed to the backend daemons.
- Added UPS functionality.
- Added rsync client and server functionality.
- Added the ability to schedule cron jobs in the GUI.
- Vastly improved and reworked snapshot replication.
Errata:
- CHAP doesn't work with GlobalSAN initiators on OS X.
- Upgrades from FreeNAS 0.7 aren't supported.
- The installer doesn't check the size of the install media before
attempting an install. A 2 GB device is required, but the install
will appear to complete successfully on smaller devices, only to fail
at boot.
- The installer will let you switch from i386 to amd64 architecture and
vice-versa, but some files, such as the rrd files used by the
statistics graphing package are architecture dependent.
- There are known interoperability issues with FreeNAS and Samba 4.x
being used as a PDC due to Samba 4.x not conforming to the Microsoft
CIFS specification and the way LDAP queries are executed on
FreeNAS. Please see the following support ticket for more details:
http://support.freenas.org/ticket/1135 .
- Shadow copies via CIFS do not work in 8.0.3. Please see
https://support.freenas.org/ticket/1186 for more details.
Filename:
FreeNAS-8.0.4-RELEASE-p2-x64.GUI_Upgrade.xz
SHA256 Hash:
b97f097b22cabfecdc390e3a35f1faf596651e81645294133c8359e9cbd868f1
Filename:
FreeNAS-8.0.4-RELEASE-p2-x64.img.xz
SHA256 Hash:
04792c7768a43669db951ed03539a6b82c47b834c2d26ac1fa70211f7823fbc1
Filename:
FreeNAS-8.0.4-RELEASE-p2-x64.iso
SHA256 Hash:
938bcafa90a3ea5d0de7b5b3aaeeab242e8be32c575cc2203bb1e278b9b574b4
Filename:
FreeNAS-8.0.4-RELEASE-p2-x86.GUI_Upgrade.xz
SHA256 Hash:
64c6cf44acc38d3a57ebcaa37c57a85eacdb03d8c1c4188e398c58c2e2893a65
Filename:
FreeNAS-8.0.4-RELEASE-p2-x86.img.xz
SHA256 Hash:
03c768b914756991fb34b0497ab585b6c7d07feeba9a8f614f66442abaf9c652
Filename:
FreeNAS-8.0.4-RELEASE-p2-x86.iso
SHA256 Hash:
b66000ac66ae02c87b8bc15a04415cf436cc8d0bbbc9540ddab42060a5dd9e35
dfsooner
GUI Upgrade from FreeNAS-8.0.4-RELEASE-p1-x64 (11059) using FreeNAS-8.0.4-RELEASE-p2-x64.GUI_Upgrade.xz doesn't seem to be working.
I downloaded it twice and attempted to upgrade multiple times. The GUI seems to accept it, but nothing happens and I can still access my data on the NAS well after initiating the upgrade.
Anyone else having a problem?
zyo
Awesome, any planning on refreshing the BETA3 or maybe even move to RC?
Bugster
I'm currently running the GUI Upgrade. The log has been showing the following : Executing: /bin/rm -fr /var/tmp/firmware/firmware.xz
It has been showing this for the last 20 minutes
moraga695
Upgraded today using the GUI from 8.04 p1 x64 to p2 with no problem. What happens when the checksum entered isn't correct? Does Freenas issue a warning or does nothing happen?
dfsooner
Wish I knew. All I get is a greyed out message to please wait. I know it takes a while to load, etc. but I let it set for quite a long time (an hour or so) and nothing happened. Some indication that it was alive and doing something would be nice. I also downloaded the checksum twice also to be sure, then copy and pasted. So I don't think that was the problem.
Bugster
So I left it runnig all night and i was still able to access my files. I just went into my Freenas and it was still showing my old version. After rebooting I noticed that it has been updated.
FreeNAS Build FreeNAS-8.0.4-RELEASE-p2-x64 (11367)
andyl
Should this be applied as a firmware update or a service pack?
Thanks.
warri
It needs to be applied as a firmware update.
dfsooner
You are correct. It shows up as the p2 release after reboot. The upgrade process should either automatically reboot or notify you to reboot manually when the process is complete. Otherwise, the person doing the upgrade has no idea when it is ready for the reboot.
jlpellet
Thanks! When I try the GUI x86 upgrade from FreeNAS-8.2.0-BETA3-x86 the console indicates a firmware error. Not sure what to try next.
This is for:
SHA256 Hash:
64c6cf44acc38d3a57ebcaa37c57a85eacdb03d8c1c4188e39 8c58c2e2893a65
andyl
Every time I attempt to apply it, I get an "invalid firmware or checksum" error.
My system currently reports as FreeNAS-8.0.4-RELEASE-p1-x64 (11059)
I'm downloading the upgrade from this link;
http://downloads.sourceforge.net/pr...reeNAS-8.0.4/&ts=1336708364&use_mirror=aarnet
And the checksum from this link;
http://downloads.sourceforge.net/pr...reeNAS-8.0.4/&ts=1336708514&use_mirror=aarnet
I've used two different download managers (DownThemAll and aria2c) and I've tried several times.
Once the file is downloaded, I click Settings/Advanced/Firemware Update in the GUI. I only have one volume which is a RAIDz array mounted under mnt so I select that for storage during the upgrade. I cut and paste the SHA key and click go. 10-15s later I get the error.
Any ideas what I'm doing wrong? Thanks!
NASbox
I ran the upgrade you mentioned a couple of days ago, and it went well... system rebooted a couple of time in the process, and when everything settled the system came up fine.
Platform Intel(R) Pentium(R) CPU G620 @ 2.60GHz
Memory 16281MB
System Time Fri May 11 17:42:12 2012
OS Version FreeBSD 8.2-RELEASE-p7
The system looks and runs the same... AFAIK the only major change is a security fix in SAMBA.
andyl
It looks like the hash I downloaded from AARNET was corrupt.
I got a hash starting 0479 from AARNET, and hashes starting b97f from two other mirrors.
I redownloaded the x64 GUI upgrade archive again from the Taiwanese mirror and all now works.
Getting the hash again from AARNET this am, it still starts 0479 so I would think it needs checking by someone who knows more than me....
Similar threads
