jimboooooo
- Feb 21, 2017
I've been looking to put together a FreeNAS build for a while now and over the last few months have been reading and piecing together a list of hardware. I have a 28TB unraid machine but that will not cut it any longer for family photos and videos, time machine backups, personal repos, etc.
I want this build to be expandable as times goes on. I went with the node 804 case because it supports up to 10 3.5" + 2 2.5" drives. I decided to go with 2 x 8TB mirrored vdevs and have the ability to add 2 more mirrored vdevs later. I've gone back and forth on raidz2 or mirrored vdevs hundreds of times now. This article pushed me into the mirrored vdev court, but I'm always open to other thoughts on the matter :). I am also planning on running a number of jails (and docker containers when that is supported) so I'm thinking of 2x500GB SSDs in raid 1 outside of the pool just for that purpose. A 4TB drive just for downloading/transcoding of media.
I went with the Supermicro x11ssl mobo because it can connect up to 14 drives. I figure I'll save the SAS connectors for the vdev drives and use the sata connections for the other drives.
Do these parts sounds alright? I'm hoping I didn't miss something obvious.
CPU: Intel - Xeon E3-1275 V5 3.6GHz Quad-Core Processor ($336.44 @ OutletPC)
Motherboard: Supermicro - X11SSL-CF Micro ATX LGA1151 Motherboard ($252.99)
Memory: Crucial - 16GB (1 x 16GB) DDR4-2133 Memory ($184.99 @ B&H)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive ($178.89 @ OutletPC)
Storage: Western Digital - Red 4TB 3.5" 5400RPM Internal Hard Drive ($133.99 @ SuperBiiz)
Storage: Western Digital - Red 8TB 3.5" 5400RPM Internal Hard Drive ($263.99 @ SuperBiiz)
Case: Fractal Design - Node 804 MicroATX Mid Tower Case ($89.99 @ SuperBiiz)
Power Supply: SeaSonic - 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.90 @ Amazon)
Case Fan: Fractal Design - FD-FAN-SSR2-120 40.6 CFM 120mm Fan ($9.88 @ OutletPC)
Case Fan: Fractal Design - FD-FAN-SSR2-140 66.0 CFM 140mm Fan ($11.99 @ SuperBiiz)
Other: SanDisk Ultra Fit 16GB USB 3.0 Flash Drive SDCZ43-016G-G46 ($10.85 @ Amazon)
Other: Tripp Lite DVI to VGA Monitor Cable, High Resolution cable with RGB Coax (DVI-A M to HD15 M) 10-ft.(P556-010) ($9.74 @ Amazon)
Total: $2770.10
Total: $2770.10
