Hi.
My motherboard thinks that one of my fans stops working every few seconds (fan speed=0) which makes it ramp up to full speed for a second or two. This is extremely annoying since I have the server in my office during the winter time. I have removed the chassi panels and made sure that the fan does indeed not spin down.
The thing is that I've had this problem before but I made it stop by changing the thresholds for when the motherboard should ramp up to max speed. Now the problem is back. I tried changing the thresholds again but without any success.
I even set them all to 0, which the MB confirms, and yet it doesn't work.
I am however pretty dumb when it comes to truenas, or pretty much anything that isn't basic windows, so maybe I'm missing something obvious?
Motherboard: Supermicro X11SSM-F
Fan: Unknown Noctua aimed for regular PC´s. If it for some reason is important to know the exact model I can look it up.
Truenas version: 13.0-U3.1
Thanks!
Thanks!
