IsaacN
- May 25, 2020
Hi everyone, I am new to FreeNAS and I keep getting this error:
CRITICAL
Device: /dev/ada0, Failed SMART usage Attribute: 184 End-to-End_Error..
Here is the smartctl -a /dev/ output
CRITICAL
Warning: settings changed through the CLI are not written to the configuration database and will be reset on reboot. root@freenas[~]# smartctl -a /dev/ada0 smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p9 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Desktop SSHD Device Model: ST1000DX001-1NS162 Serial Number: Z4Y8NBBH LU WWN Device Id: 5 000c50 07bba68ce Firmware Version: CC41 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Mon May 25 19:36:40 2020 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 114) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x1081) SCT Status supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 198377872 3 Spin_Up_Time 0x0003 097 097 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 273 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 088 060 030 Pre-fail Always - 733841853 9 Power_On_Hours 0x0032 064 064 000 Old_age Always - 32187 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 289 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 099 099 099 Old_age Always FAILING_NOW 1 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 0 0 1 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 077 045 045 Old_age Always In_the_past 23 (Min/Max 18/23) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 126 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 309 194 Temperature_Celsius 0x0022 023 055 000 Old_age Always - 23 (0 16 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 32738h+00m+13.514s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 107105658155 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 868388742747 SMART Error Log Version: 1 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 28457 hours (1185 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 50 de fc 01 Error: UNC at LBA = 0x01fcde50 = 33349200 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 28 48 de fc e1 00 00:03:14.035 READ DMA EXT 25 00 20 a8 8b f7 e1 00 00:03:14.035 READ DMA EXT 25 00 20 58 ba f2 e1 00 00:03:14.034 READ DMA EXT 25 00 10 18 c2 d9 e1 00 00:03:14.031 READ DMA EXT 25 00 08 ff ff ff ef 00 00:03:14.031 READ DMA EXT SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 32174 - # 2 Extended offline Completed without error 00% 32150 - # 3 Extended offline Completed without error 00% 32127 - # 4 Extended offline Completed without error 00% 32103 - # 5 Extended offline Completed without error 00% 32081 - # 6 Extended offline Completed without error 00% 32057 - # 7 Extended offline Completed without error 00% 32033 - # 8 Extended offline Completed without error 00% 32009 - # 9 Extended offline Completed without error 00% 31985 - #10 Extended offline Completed without error 00% 31961 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
