SMART error that I ignore?
calgarychris
Hi, I'm a newb - please be kind! :) I've searched the forums and I can't find a clear answer...I got an email alert today that read:
The following warning/error was logged by the smartd daemon:
Device: /dev/ada2, ATA error count increased from 0 to 2
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
I don't know how to see the SYSLOG, but I did run smartctl -a on /dev/ada2 which gave the information below (sorry for the long post):
Is this something I need to worry about or can it be safely ignored?
Thanks very much!
Chris
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (24155) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 255) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 96
3 Spin_Up_Time 0x0007 135 135 024 Pre-fail Always - 406 (Average 407)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 3991
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 146 146 020 Pre-fail Offline - 29
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 4391
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 90
192 Power-Off_Retract_Count 0x0032 097 097 000 Old_age Always - 3993
193 Load_Cycle_Count 0x0012 097 097 000 Old_age Always - 3993
194 Temperature_Celsius 0x0002 222 222 000 Old_age Always - 27 (Min/Max 17/39)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 2 occurred at disk power-on lifetime: 4389 hours (182 days + 21 hours)
ER ST SC SN CL CH DH
40 51 6b 57 ac cd 04 Error: UNC at LBA = 0x04cdac57 = 80587863
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 55 6b 57 ac cd 44 ff 1d+08:05:07.702 READ FPDMA QUEUED
60 55 70 c3 ad cd 40 00 1d+08:05:07.701 READ FPDMA QUEUED
60 55 68 18 ad cd 40 00 1d+08:05:07.701 READ FPDMA QUEUED
60 ab 60 17 ac cd 40 00 1d+08:05:07.701 READ FPDMA QUEUED
60 ab 60 6c ab cd 40 00 1d+08:05:07.696 READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 4389 hours (182 days + 21 hours)
40 51 6c 56 ac cd 04 Error: UNC at LBA = 0x04cdac56 = 80587862
60 00 58 6c aa cd 40 00 1d+08:05:07.696 READ FPDMA QUEUED
# 1 Short offline Completed without error 00% 4376 -
# 2 Short offline Completed without error 00% 4352 -
# 3 Short offline Completed without error 00% 4328 -
# 4 Short offline Completed without error 00% 4305 -
# 5 Short offline Completed without error 00% 4280 -
# 6 Short offline Completed without error 00% 4256 -
# 7 Short offline Completed without error 00% 4232 -
# 8 Short offline Completed without error 00% 4208 -
# 9 Short offline Completed without error 00% 4184 -
#10 Short offline Completed without error 00% 4160 -
#11 Short offline Completed without error 00% 4138 -
#12 Short offline Completed without error 00% 4112 -
#13 Short offline Completed without error 00% 4088 -
#14 Short offline Completed without error 00% 4064 -
#15 Short offline Completed without error 00% 4040 -
#16 Short offline Completed without error 00% 4016 -
#17 Short offline Completed without error 00% 3992 -
#18 Short offline Completed without error 00% 3968 -
#19 Short offline Completed without error 00% 3944 -
#20 Short offline Completed without error 00% 3920 -
#21 Short offline Completed without error 00% 3896 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
calgarychris
Thanks William - can you tell if it means there are bad sectors, some sort of permanent damage? How can you tell it looks okay and what would tell me it's about to fail?
Thanks!
Chris
William Grzybowski
Those seem to be the most critical... And they tell there are no pending sectors neither uncorrectable, which is good.
I would start worrying when they start increasing...
calgarychris
Thanks very much - figure I might as well try to learn! :) So, good news and no need to panic just yet...
