dash
- Jul 9, 2015
Been getting SMART errors on my console. Seen drives fail, but given the life of this drive I am a little surprised. Drive is 5+ years old. NAS has been mostly turn/off as use. Recently moved it into a new case and keeping it on 24/7.
Looking at similar posts and see that most people with this error are showing where the `LBA_of_first_error` is and can tell the drive to stop using the sectors or that their drive is hosed. Hoping someone could shed a little light on my error since its showing blank. Assuming the drive is hitting unreadable sectores and failing the scan. I am going to have to replace the drive. but if I can avoid shelling out ~$250 for a new one I would like to.
May 20 16:00:05 freenas smartd[17511]: Device: /dev/ada1, 384 Currently unreadable (pending) sectors May 20 16:00:05 freenas smartd[17511]: Device: /dev/ada1, 384 Offline uncorrectable sectors
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Archive HDD Device Model: ST8000AS0002-1NA17Z Serial Number: Z840AKWB LU WWN Device Id: 5 000c50 087451193 Firmware Version: AR15 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5980 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Wed May 20 16:29:56 2020 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 966) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x30a5) SCT Status supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 120 088 006 Pre-fail Always - 243927232 3 Spin_Up_Time 0x0003 091 090 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 53 5 Reallocated_Sector_Ct 0x0033 099 099 010 Pre-fail Always - 1344 7 Seek_Error_Rate 0x000f 074 060 030 Pre-fail Always - 34564692991 9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2600 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 51 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 090 090 000 Old_age Always - 10 188 Command_Timeout 0x0032 100 097 000 Old_age Always - 73015558161 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 064 060 045 Old_age Always - 36 (Min/Max 22/37) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 102 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 147 194 Temperature_Celsius 0x0022 036 040 000 Old_age Always - 36 (0 19 0 0 0) 195 Hardware_ECC_Recovered 0x001a 120 099 000 Old_age Always - 243927232 197 Current_Pending_Sector 0x0012 099 099 000 Old_age Always - 384 198 Offline_Uncorrectable 0x0010 099 099 000 Old_age Offline - 384 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2595 (15 227 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 7237368292 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 166220301821 SMART Error Log Version: 1 ATA Error Count: 10 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 10 occurred at disk power-on lifetime: 2492 hours (103 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 3d+08:29:50.017 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:50.016 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:50.016 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:29:49.954 READ LOG EXT 60 00 08 ff ff ff 4f 00 3d+08:29:47.007 READ FPDMA QUEUED Error 9 occurred at disk power-on lifetime: 2492 hours (103 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 3d+08:29:47.007 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:47.007 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:47.006 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:47.006 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:29:46.933 READ LOG EXT Error 8 occurred at disk power-on lifetime: 2492 hours (103 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 3d+08:29:44.084 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:44.005 READ FPDMA QUEUED 61 00 28 ff ff ff 4f 00 3d+08:29:44.004 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:44.004 READ FPDMA QUEUED 61 00 40 ff ff ff 4f 00 3d+08:29:44.004 WRITE FPDMA QUEUED Error 7 occurred at disk power-on lifetime: 2492 hours (103 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 3d+08:29:40.936 READ FPDMA QUEUED 61 00 30 ff ff ff 4f 00 3d+08:29:40.924 WRITE FPDMA QUEUED 61 00 00 ff ff ff 4f 00 3d+08:29:40.924 WRITE FPDMA QUEUED 61 00 b0 ff ff ff 4f 00 3d+08:29:40.923 WRITE FPDMA QUEUED 61 00 78 ff ff ff 4f 00 3d+08:29:40.923 WRITE FPDMA QUEUED Error 6 occurred at disk power-on lifetime: 2492 hours (103 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 3d+08:29:37.453 READ FPDMA QUEUED 61 00 08 ff ff ff 4f 00 3d+08:29:37.453 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:37.205 READ FPDMA QUEUED 60 00 10 ff ff ff 4f 00 3d+08:29:37.199 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 3d+08:29:36.992 READ FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 20% 2330 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
pool: storage state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: resilvered 264K in 0 days 00:00:03 with 0 errors on Sat May 16 04:30:04 2020 config: NAME STATE READ WRITE CKSUM storage ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/701b325b-3fd5-11e6-a190-00259031c250 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 gptid/71dc6ac6-3fd5-11e6-a190-00259031c250 ONLINE 0 0 0 gptid/72ba9a86-3fd5-11e6-a190-00259031c250 ONLINE 0 0 0 errors: No known data errors
