2dfx
- Nov 16, 2020
So after logging into my TrueNAS box today, I discovered this my result of smartctl -a on ada2:
...I would assume that ada2 is pooched. The odd thing is that the pool isn't listed as degraded...any idea why?
Just to make sure I have everything right, am I right in saying this is the procedure:
1. Offline the drive in FreeNAS, then shut down
2. Restart the machine, online the drive
3. Select 'replace drive' in the GUI, select it and wait for the re-silver
Am I missing anything? Thanks for the help!
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p11 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate BarraCuda 3.5 Device Model: ST10000DM0004-1ZC101 Serial Number: ZA2ARDS2 LU WWN Device Id: 5 000c50 0b5730512 Firmware Version: DN01 User Capacity: 10,000,831,348,736 bytes [10.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Dec 9 22:36:01 2021 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 575) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 893) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 055 054 044 Pre-fail Always - 160370923 3 Spin_Up_Time 0x0003 089 089 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 28 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 1009 7 Seek_Error_Rate 0x000f 096 060 045 Pre-fail Always - 4254269109 9 Power_On_Hours 0x0032 081 081 000 Old_age Always - 16692 (83 54 0) 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 27 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 553 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 072 062 040 Old_age Always - 28 (Min/Max 25/30) 191 G-Sense_Error_Rate 0x0032 098 098 000 Old_age Always - 5116 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 12 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 170 194 Temperature_Celsius 0x0022 028 040 000 Old_age Always - 28 (0 21 0 0 0) 195 Hardware_ECC_Recovered 0x001a 032 001 000 Old_age Always - 160370923 197 Current_Pending_Sector 0x0012 099 096 000 Old_age Always - 951 198 Offline_Uncorrectable 0x0010 099 096 000 Old_age Offline - 951 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Pressure_Limit 0x0023 100 100 001 Pre-fail Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 16673h+12m+20.325s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 26707962502 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 47106578234 SMART Error Log Version: 1 ATA Error Count: 553 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 553 occurred at disk power-on lifetime: 16692 hours (695 days + 12 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 01 ff ff ff 4f 00 3d+08:05:09.705 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:09.670 READ LOG EXT 60 00 01 ff ff ff 4f 00 3d+08:05:07.472 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:07.462 READ LOG EXT 60 00 01 ff ff ff 4f 00 3d+08:05:05.256 READ FPDMA QUEUED Error 552 occurred at disk power-on lifetime: 16692 hours (695 days + 12 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 01 ff ff ff 4f 00 3d+08:05:07.472 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:07.462 READ LOG EXT 60 00 01 ff ff ff 4f 00 3d+08:05:05.256 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:05.221 READ LOG EXT 61 00 08 ff ff ff 4f 00 3d+08:05:02.981 WRITE FPDMA QUEUED Error 551 occurred at disk power-on lifetime: 16692 hours (695 days + 12 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 01 ff ff ff 4f 00 3d+08:05:05.256 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:05.221 READ LOG EXT 61 00 08 ff ff ff 4f 00 3d+08:05:02.981 WRITE FPDMA QUEUED 60 00 01 ff ff ff 4f 00 3d+08:05:02.981 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:02.971 READ LOG EXT Error 550 occurred at disk power-on lifetime: 16692 hours (695 days + 12 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 08 ff ff ff 4f 00 3d+08:05:02.981 WRITE FPDMA QUEUED 60 00 01 ff ff ff 4f 00 3d+08:05:02.981 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 3d+08:05:02.971 READ LOG EXT 61 00 08 ff ff ff 4f 00 3d+08:05:00.745 WRITE FPDMA QUEUED 61 00 10 ff ff ff 4f 00 3d+08:05:00.743 WRITE FPDMA QUEUED Error 549 occurred at disk power-on lifetime: 16692 hours (695 days + 12 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 08 ff ff ff 4f 00 3d+08:05:00.745 WRITE FPDMA QUEUED 61 00 10 ff ff ff 4f 00 3d+08:05:00.743 WRITE FPDMA QUEUED 61 00 08 ff ff ff 4f 00 3d+08:05:00.743 WRITE FPDMA QUEUED 61 00 08 ff ff ff 4f 00 3d+08:05:00.743 WRITE FPDMA QUEUED 61 00 08 ff ff ff 4f 00 3d+08:05:00.743 WRITE FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 10% 16575 - # 2 Short offline Completed without error 00% 16407 - # 3 Short offline Completed without error 00% 16239 - # 4 Short offline Completed without error 00% 16071 - # 5 Short offline Completed without error 00% 15903 - # 6 Short offline Completed without error 00% 15735 - # 7 Short offline Completed without error 00% 15567 - # 8 Short offline Completed without error 00% 15399 - # 9 Short offline Completed without error 00% 15231 - #10 Short offline Completed without error 00% 15063 - #11 Short offline Completed without error 00% 14895 - #12 Short offline Completed without error 00% 14727 - #13 Short offline Completed without error 00% 14559 - #14 Short offline Completed without error 00% 14392 - #15 Short offline Completed without error 00% 14224 - #16 Short offline Completed without error 00% 14056 - #17 Short offline Completed without error 00% 13888 - #18 Short offline Completed without error 00% 13720 - #19 Short offline Completed without error 00% 13552 - #20 Short offline Completed without error 00% 13384 - #21 Short offline Completed without error 00% 13216 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing
