SOLVED Error "Device: /dev/ada0, Self-Test Log error count increased from 1 to 2."
Mat_Dum
[Excuse the language mistakes, I am French and my English is not very good]
Hi everyone,
I have 2 disks of 1To in my server in mirror, and recently an alert appeared indicating that 2 sectors are unreadable and not correctable. So I would like to know how to fix these sectors or disable them to avoid other problems.
I point out that this server is built from scrap parts and is not used to store important data. Also, I wish I didn't have to buy new hard drives if they weren't broken.
PC : Dell Optiplex 3010
CPU : i3-3020@3,30 GHz
RAM : 8Go DDR3
HDD#1 : 1To Segate Barracuda LP @5900rpm
HDD#2 : 1To Samsung @5400rpm
System disk : PNY USB stick 3.0
Network card : Internal card Gigabit Ethernet
Interface : Switch Gigabit Ethernet, CAT6 cable, router Gigabit Ethernet
I don't quite understand what all this information is:
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda LP
Device Model: ST31000520AS
Serial Number: 5VX1AY9K
LU WWN Device Id: 5 000c50 02f6ce78d
Firmware Version: CC38
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Wed Apr 28 17:04:04 2021 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 623) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 219) minutes.
Conveyance self-test routine
SCT capabilities: (0x103f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 146446223
3 Spin_Up_Time 0x0003 095 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 943
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 078 060 030 Pre-fail Always - 72837355
9 Power_On_Hours 0x0032 037 037 000 Old_age Always - 55700
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 471
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 088 088 000 Old_age Always - 12
188 Command_Timeout 0x0032 100 001 000 Old_age Always - 9331
189 High_Fly_Writes 0x003a 086 086 000 Old_age Always - 14
190 Airflow_Temperature_Cel 0x0022 069 050 045 Old_age Always - 31 (Min/Max 31/32)
194 Temperature_Celsius 0x0022 031 050 000 Old_age Always - 31 (0 7 0 0 0)
195 Hardware_ECC_Recovered 0x001a 044 021 000 Old_age Always - 146446223
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 2
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 2
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 31920 (98 100 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1014621763
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 211492647
SMART Error Log Version: 1
ATA Error Count: 11 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 11 occurred at disk power-on lifetime: 55695 hours (2320 days + 15 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 01 ff ff ff 4f 00 02:43:49.055 READ FPDMA QUEUED
2f 00 01 10 00 00 40 00 02:43:48.994 READ LOG EXT
60 00 01 ff ff ff 4f 00 02:43:45.623 READ FPDMA QUEUED
2f 00 01 10 00 00 40 00 02:43:45.617 READ LOG EXT
60 00 01 ff ff ff 4f 00 02:43:41.923 READ FPDMA QUEUED
Error 10 occurred at disk power-on lifetime: 55695 hours (2320 days + 15 hours)
2f 00 01 10 00 00 40 00 02:43:41.853 READ LOG EXT
60 00 01 ff ff ff 4f 00 02:43:38.209 READ FPDMA QUEUED
Error 9 occurred at disk power-on lifetime: 55695 hours (2320 days + 15 hours)
2f 00 01 10 00 00 40 00 02:43:38.201 READ LOG EXT
60 00 01 ff ff ff 4f 00 02:43:34.552 READ FPDMA QUEUED
2f 00 01 10 00 00 40 00 02:43:34.528 READ LOG EXT
60 00 01 ff ff ff 4f 00 02:43:30.875 READ FPDMA QUEUED
Error 8 occurred at disk power-on lifetime: 55695 hours (2320 days + 15 hours)
2f 00 01 10 00 00 40 00 02:43:30.805 READ LOG EXT
60 00 01 ff ff ff 4f 00 02:43:27.146 READ FPDMA QUEUED
Error 7 occurred at disk power-on lifetime: 55695 hours (2320 days + 15 hours)
60 00 01 ff ff ff 4f 00 02:43:27.145 READ FPDMA QUEUED
# 1 Extended offline Completed: read failure 90% 55698 1770307436
# 2 Extended offline Completed: read failure 90% 55696 1770307436
# 3 Extended offline Interrupted (host reset) 00% 55693 -
# 4 Short offline Completed without error 00% 55690 -
# 5 Extended offline Completed: read failure 10% 55688 1770307436
# 6 Short offline Completed without error 00% 55668 -
# 7 Short offline Completed without error 00% 55644 -
# 8 Short offline Completed without error 00% 55620 -
# 9 Short offline Completed without error 00% 55596 -
#10 Short offline Completed without error 00% 55572 -
#11 Short offline Completed without error 00% 55548 -
#12 Short offline Completed without error 00% 55524 -
#13 Short offline Completed without error 00% 55500 -
#14 Short offline Completed without error 00% 55476 -
#15 Short offline Completed without error 00% 55452 -
#16 Short offline Completed without error 00% 55428 -
#17 Short offline Completed without error 00% 55404 -
#18 Short offline Completed without error 00% 55380 -
#19 Short offline Completed without error 00% 55356 -
#20 Short offline Completed without error 00% 55332 -
#21 Short offline Completed without error 00% 55308 -
1 0 0 Not_testing
2 0 0 Not_testing
thank you in advance for your help
[I am new to using Truenas, I do not yet know all the available features]
Jailer
Not strong, but bad
Your disk has failed 3 smart long test. Replace the disk if you value your data.
GBillR
That drive has over over 6 years of power on time. I'm actually impressed that it has taken this long to throw errors given that it is not a NAS or DataCenter Drive. At least you were running SMART tests... hopefully you are also running regular scrubs.
As @Jailer has stated, that drive is on it's way to the graveyard. No telling how much longer it will last, but at that age, it is only a matter of time before you have much bigger issues. Since you have a mirror, your data is still safe for now... until the other drive starts to have issues. Since you don't provide info on the age or condition of that other drive, I can only assume it to be of the same vintage and class.
If you don't have a backup of the data somewhere else, you should do so as soon as possible.
Mat_Dum
The ada0 disc dates from 2009 and ada1 from 2014. They were used in desktop PCs (everything is recycled). I should be able to find a 1TB drive in one of my computers to replace it and I will look at the condition of the second drive to see if it can still be used.
Thank you very much for all your valuable advice
