Hello team,
I got the error message and here is the result of smartctl -x command. This hard drive should be replaced ASAP?
I appreciate for your help on this!!
smartctl -x /dev/ada0
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WMC4N0E6DD4T
LU WWN Device Id: 5 0014ee 65a60cf29
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Feb 28 10:40:20 2024 JST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (39840) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 399) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 20
3 Spin_Up_Time POS--K 177 175 021 - 6150
4 Start_Stop_Count -O--CK 100 100 000 - 108
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 004 004 000 - 70751
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 107
192 Power-Off_Retract_Count -O--CK 200 200 000 - 56
193 Load_Cycle_Count -O--CK 200 200 000 - 1026
194 Temperature_Celsius -O---K 118 098 000 - 32
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 1
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 16
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 16 [15] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 01 46 b9 da 88 40 00 Error: UNC at LBA = 0x146b9da88 = 5481552520
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 08 00 00 00 01 46 b9 da 88 40 08 16:48:22.232 READ FPDMA QUEUED
ef 00 02 00 00 00 00 00 00 00 00 40 00 16:48:22.231 SET FEATURES [Enable write cache]
ef 00 aa 00 00 00 00 00 00 00 00 40 00 16:48:22.231 SET FEATURES [Enable read look-ahead]
c6 00 00 00 10 00 00 00 00 00 00 40 00 16:48:22.231 SET MULTIPLE MODE
ef 00 10 00 02 00 00 00 00 00 00 40 00 16:48:22.231 SET FEATURES [Enable SATA feature]
Error 15 [14] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
60 00 08 00 c0 00 00 02 95 76 88 40 08 16:48:17.537 READ FPDMA QUEUED
60 00 08 00 b8 00 01 46 b9 da 88 40 08 16:48:17.537 READ FPDMA QUEUED
ef 00 02 00 00 00 00 00 00 00 00 40 00 16:48:17.536 SET FEATURES [Enable write cache]
ef 00 aa 00 00 00 00 00 00 00 00 40 00 16:48:17.536 SET FEATURES [Enable read look-ahead]
c6 00 00 00 10 00 00 00 00 00 00 40 00 16:48:17.536 SET MULTIPLE MODE
Error 14 [13] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
60 00 08 00 78 00 01 46 b9 da 88 40 08 16:48:12.806 READ FPDMA QUEUED
ef 00 02 00 00 00 00 00 00 00 00 40 00 16:48:12.806 SET FEATURES [Enable write cache]
ef 00 aa 00 00 00 00 00 00 00 00 40 00 16:48:12.806 SET FEATURES [Enable read look-ahead]
c6 00 00 00 10 00 00 00 00 00 00 40 00 16:48:12.806 SET MULTIPLE MODE
ef 00 10 00 02 00 00 00 00 00 00 40 00 16:48:12.806 SET FEATURES [Enable SATA feature]
Error 13 [12] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
60 00 08 00 38 00 01 3f b6 e0 08 40 08 16:48:08.078 READ FPDMA QUEUED
60 00 08 00 30 00 01 46 b9 da 88 40 08 16:48:08.078 READ FPDMA QUEUED
ef 00 02 00 00 00 00 00 00 00 00 40 00 16:48:08.078 SET FEATURES [Enable write cache]
ef 00 aa 00 00 00 00 00 00 00 00 40 00 16:48:08.078 SET FEATURES [Enable read look-ahead]
c6 00 00 00 10 00 00 00 00 00 00 40 00 16:48:08.078 SET MULTIPLE MODE
Error 12 [11] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
60 00 08 00 e8 00 01 46 b9 da 88 40 08 16:48:03.307 READ FPDMA QUEUED
61 00 10 00 e0 00 01 4c 54 36 78 40 08 16:48:03.305 WRITE FPDMA QUEUED
61 00 08 00 d8 00 01 4b 9e ec 60 40 08 16:48:03.305 WRITE FPDMA QUEUED
61 00 10 00 d0 00 00 02 fa af a8 40 08 16:48:03.305 WRITE FPDMA QUEUED
61 00 10 00 c8 00 00 01 97 46 f0 40 08 16:48:03.305 WRITE FPDMA QUEUED
Error 11 [10] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
40 -- 51 00 00 00 01 47 bb cc 88 40 00 Error: UNC at LBA = 0x147bbcc88 = 5498457224
60 00 10 00 f8 00 01 46 fc 5f 78 40 08 16:46:19.801 READ FPDMA QUEUED
60 00 08 00 f0 00 01 46 fc 5f b0 40 08 16:46:19.801 READ FPDMA QUEUED
60 00 08 00 e8 00 01 47 bb cc 88 40 08 16:46:19.801 READ FPDMA QUEUED
ef 00 02 00 00 00 00 00 00 00 00 40 00 16:46:19.801 SET FEATURES [Enable write cache]
ef 00 aa 00 00 00 00 00 00 00 00 40 00 16:46:19.801 SET FEATURES [Enable read look-ahead]
Error 10 [9] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
60 00 08 00 a8 00 01 48 46 e9 88 40 08 16:46:15.116 READ FPDMA QUEUED
60 00 10 00 a0 00 01 46 fc 5f 78 40 08 16:46:15.116 READ FPDMA QUEUED
60 00 08 00 98 00 01 46 fc 5f b0 40 08 16:46:15.116 READ FPDMA QUEUED
60 00 08 00 90 00 01 47 bb cc 88 40 08 16:46:15.116 READ FPDMA QUEUED
ef 00 02 00 00 00 00 00 00 00 00 40 00 16:46:15.116 SET FEATURES [Enable write cache]
Error 9 [8] occurred at disk power-on lifetime: 4853 hours (202 days + 5 hours)
60 00 08 00 50 00 01 48 46 e9 88 40 08 16:46:10.258 READ FPDMA QUEUED
61 02 80 00 48 00 01 3f bf 5d 88 40 08 16:46:10.258 WRITE FPDMA QUEUED
61 00 40 00 40 00 01 3f bf 5d 48 40 08 16:46:10.257 WRITE FPDMA QUEUED
61 02 80 00 38 00 01 3f bf 5a c8 40 08 16:46:10.256 WRITE FPDMA QUEUED
61 00 c0 00 30 00 01 3f bf 5a 08 40 08 16:46:10.256 WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed: read failure 90% 5214 49975150
# 2 Short offline Completed without error 00% 4811 -
# 3 Short offline Completed without error 00% 4787 -
# 4 Short offline Completed without error 00% 4763 -
# 5 Short offline Completed without error 00% 4739 -
# 6 Extended offline Completed without error 00% 23297 -
# 7 Extended offline Completed without error 00% 23288 -
# 8 Extended offline Completed without error 00% 23280 -
# 9 Extended offline Completed without error 00% 23272 -
#10 Extended offline Completed without error 00% 23263 -
#11 Extended offline Completed without error 00% 23256 -
#12 Extended offline Completed without error 00% 23247 -
#13 Extended offline Completed without error 00% 23239 -
#14 Extended offline Completed without error 00% 23231 -
#15 Extended offline Completed without error 00% 23222 -
#16 Extended offline Completed without error 00% 23214 -
#17 Extended offline Completed without error 00% 23205 -
#18 Extended offline Completed without error 00% 23197 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 32 Celsius
Power Cycle Min/Max Temperature: 23/39 Celsius
Lifetime Min/Max Temperature: 2/52 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (144)
Index Estimated Time Temperature Celsius
145 2024-02-28 02:43 31 ************
... ..(185 skipped). .. ************
331 2024-02-28 05:49 31 ************
332 2024-02-28 05:50 32 *************
... ..(286 skipped). .. *************
141 2024-02-28 10:37 32 *************
142 2024-02-28 10:38 31 ************
143 2024-02-28 10:39 31 ************
144 2024-02-28 10:40 31 ************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 18 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 19 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 1364583 Vendor specific
was never started.
command.
power-saving mode.
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
ER = Error register
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Vendor specific:
