Hello, I got new alert, better exchange the harddrive?
zpool status, seems clear
smartctl -a /dev/da7 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Desktop HDD.15 Device Model: ST4000DM000-2AE166 Serial Number: xxxxxx LU WWN Device Id: 5 000c50 0928ec9a0 Firmware Version: 0001 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5980 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue Mar 19 11:11:30 2019 -03 SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 591) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 633) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x10a5) SCT Status supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 071 062 006 Pre-fail Always - 94367736 3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 1 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 128 7 Seek_Error_Rate 0x000f 086 060 045 Pre-fail Always - 427549635 9 Power_On_Hours 0x0032 081 081 000 Old_age Always - 17222 (252 151 0) 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 1 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 068 068 000 Old_age Always - 32 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 072 057 040 Old_age Always - 28 (Min/Max 22/43) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 715 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 931 194 Temperature_Celsius 0x0022 028 043 000 Old_age Always - 28 (0 22 0 0 0) 197 Current_Pending_Sector 0x0012 099 099 000 Old_age Always - 104 198 Offline_Uncorrectable 0x0010 099 099 000 Old_age Offline - 104 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 17141h+57m+56.146s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 37940061236 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 39575597717 SMART Error Log Version: 1 ATA Error Count: 32 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 32 occurred at disk power-on lifetime: 17198 hours (716 days + 14 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 20 ff ff ff 4f 00 20d+16:09:41.514 READ FPDMA QUEUED 60 00 f8 ff ff ff 4f 00 20d+16:09:38.789 READ FPDMA QUEUED 60 00 00 ff ff ff 4f 00 20d+16:09:38.788 READ FPDMA QUEUED 60 00 18 ff ff ff 4f 00 20d+16:09:38.787 READ FPDMA QUEUED 60 00 18 ff ff ff 4f 00 20d+16:09:38.786 READ FPDMA QUEUED Error 31 occurred at disk power-on lifetime: 17198 hours (716 days + 14 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 08 ff ff ff 4f 00 20d+16:09:19.999 WRITE FPDMA QUEUED 60 00 20 ff ff ff 4f 00 20d+16:09:19.999 READ FPDMA QUEUED 60 00 20 ff ff ff 4f 00 20d+16:09:17.295 READ FPDMA QUEUED 60 00 e8 ff ff ff 4f 00 20d+16:09:17.295 READ FPDMA QUEUED 60 00 18 ff ff ff 4f 00 20d+16:09:17.290 READ FPDMA QUEUED Error 30 occurred at disk power-on lifetime: 17198 hours (716 days + 14 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 08 ff ff ff 4f 00 20d+16:09:10.374 WRITE FPDMA QUEUED 60 00 20 ff ff ff 4f 00 20d+16:09:10.374 READ FPDMA QUEUED 60 00 18 ff ff ff 4f 00 20d+16:09:10.374 READ FPDMA QUEUED 60 00 e8 ff ff ff 4f 00 20d+16:09:07.398 READ FPDMA QUEUED 60 00 90 ff ff ff 4f 00 20d+16:09:07.398 READ FPDMA QUEUED Error 29 occurred at disk power-on lifetime: 17198 hours (716 days + 14 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 18 ff ff ff 4f 00 20d+16:08:47.847 READ FPDMA QUEUED 60 00 18 ff ff ff 4f 00 20d+16:08:47.847 READ FPDMA QUEUED 60 00 78 ff ff ff 4f 00 20d+16:08:44.559 READ FPDMA QUEUED 60 00 00 ff ff ff 4f 00 20d+16:08:44.559 READ FPDMA QUEUED 60 00 20 ff ff ff 4f 00 20d+16:08:44.558 READ FPDMA QUEUED Error 28 occurred at disk power-on lifetime: 17198 hours (716 days + 14 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 20 ff ff ff 4f 00 20d+16:08:36.949 READ FPDMA QUEUED 60 00 20 ff ff ff 4f 00 20d+16:08:36.949 READ FPDMA QUEUED 60 00 18 ff ff ff 4f 00 20d+16:08:36.949 READ FPDMA QUEUED 60 00 b8 ff ff ff 4f 00 20d+16:08:33.939 READ FPDMA QUEUED 60 00 00 ff ff ff 4f 00 20d+16:08:33.939 READ FPDMA QUEUED SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
zpool status pool: DATA state: ONLINE scan: scrub repaired 0 in 0 days 14:07:19 with 0 errors on Sun Mar 10 14:07:21 2019 config: NAME STATE READ WRITE CKSUM DATA ONLINE 0 0 0 raidz3-0 ONLINE 0 0 0 gptid/4ba5b5bd-8495-17c0-fef1-fe7712051e8b ONLINE 0 0 0 gptid/bca8430d-d85c-22cd-e315-e1b4aee1b3f0 ONLINE 0 0 0 gptid/6bfcf742-46a5-4fcf-ee05-d8ca7c7cfde4 ONLINE 0 0 0 gptid/04829298-ffef-f468-9b28-bfe58f512d5d ONLINE 0 0 0 gptid/74c95500-19d3-fd63-e4cf-9167ed2ec61a ONLINE 0 0 0 gptid/8c180379-888b-304d-bc59-a2fcf0e811ee ONLINE 0 0 0 gptid/0d7d96b9-5fe0-68c0-f140-940a9ddb7ff0 ONLINE 0 0 0 gptid/c416dc3e-5858-27c4-c9ee-a1e652679740 ONLINE 0 0 0 gptid/2913eb66-894b-3c69-8ca5-ea1cef04495c ONLINE 0 0 0 gptid/96603dd3-2504-056a-c261-8e3b467e7276 ONLINE 0 0 0 gptid/e450f563-84d2-8667-b9e3-f1134bbc903f ONLINE 0 0 0 gptid/3b6329c1-efd5-cacf-8845-8ee6009e9387 ONLINE 0 0 0 spares da5p1 AVAIL errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:00:07 with 0 errors on Tue Mar 19 03:45:07 2019 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 da0p2 ONLINE 0 0 0 da1p2 ONLINE 0 0 0 errors: No known data errors
