First off my setup:
Case: U-Nas NSC-800
Motherboard: ASRock Rack C236 WSI LGA1151 Mini-ITX
CPU: Intel 7100T i3
Memory: 16GB(2x8) Crucial Ballistix DDR4 Non-ECC
Boot: 2-Sandisk 60GB SSD's
Storage1: 6-4TB Drives(3-WD WD4002FYYZ, 2-WD Se WD4000F9YZ, and 1-WD Re WD4000FYYZ)
Storage2: WD 1TB USB External Drive externally powered
Card: LSI 9211-8i with P20 IT Mode
PSU: 320W 1U
Freenas: 11.2-U4.1
Error I keep getting:
The error is occurring on the 2 drives I have on the LSI card. No matter which 2 drives I use I get I get the above error always on one of them, either da0 or da1. Smart says all of the drives are good. I have tried 2 LSI cards. I have tried a fan on both of the cards. 2 motherboards(the other one is a ASRock Z170 Gamers Mini-ITX board). I have tried 2 different SFF-8087 cables. I have tried 2 power supplies, the original 320W and a ATX 450W. I have tried a new Freenas installation and then uploading the config multiple times. All of the drive and cpu temps are ~40C or a little less. Drives work fine on the built-in SATA controller.
zpool status:
smartctl -a /dev/da0:
smartctl -a /dev/da1
I have spent about a month trying to get this card playing nice which is odd because it seems to work for people on here.
Case: U-Nas NSC-800
CPU: Intel 7100T i3
PSU: 320W 1U
Freenas: 11.2-U4.1
Jun 1 16:53:17 Server (da1:mps0:0:7:0): Retrying command (per sense data) Jun 1 16:53:18 Server (da1:mps0:0:7:0): WRITE(10). CDB: 2a 00 00 ce 71 20 00 01 00 00 Jun 1 16:53:18 Server (da1:mps0:0:7:0): CAM status: SCSI Status Error Jun 1 16:53:18 Server (da1:mps0:0:7:0): SCSI status: Check Condition Jun 1 16:53:18 Server (da1:mps0:0:7:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
zpool status:
zpool status pool: Stuff state: ONLINE scan: resilvered 504K in 0 days 00:00:01 with 0 errors on Sat Jun 1 14:27:25 2019 config: NAME STATE READ WRITE CKSUM Stuff ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/0bb68bd6-622c-11e9-b921-d05099747709 ONLINE 0 0 0 ada3p2 ONLINE 0 0 0 mirror-1 ONLINE 0 0 0 gptid/0fc260e1-622c-11e9-b921-d05099747709 ONLINE 0 0 0 gptid/11d42ffe-622c-11e9-b921-d05099747709 ONLINE 0 0 0 mirror-2 ONLINE 0 0 0 gptid/1444461f-622c-11e9-b921-d05099747709 ONLINE 0 0 0 gptid/171f74a0-622c-11e9-b921-d05099747709 ONLINE 0 0 0 errors: No known data errors
root@Server:~ # smartctl -a /dev/da0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Gold Device Model: WDC WD4002FYYZ-01B7CB0 Serial Number: N8GYBAXY LU WWN Device Id: 5 000cca 244cd5960 Firmware Version: 01.01M02 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Jun 1 18:40:13 2019 MDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 113) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 571) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 108 3 Spin_Up_Time 0x0007 150 150 024 Pre-fail Always - 368 (Average 343) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 200 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 9738 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 196 192 Power-Off_Retract_Count 0x0032 093 093 000 Old_age Always - 8802 193 Load_Cycle_Count 0x0012 093 093 000 Old_age Always - 8802 194 Temperature_Celsius 0x0002 100 100 000 Old_age Always - 60 (Min/Max 17/60) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 203 SMART Error Log Version: 1 ATA Error Count: 203 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 203 occurred at disk power-on lifetime: 9735 hours (405 days + 15 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 00 b8 51 54 40 00 00:03:23.598 WRITE FPDMA QUEUED 61 00 28 b8 56 54 40 00 00:03:23.597 WRITE FPDMA QUEUED 61 00 20 b8 55 54 40 00 00:03:23.597 WRITE FPDMA QUEUED 61 00 18 b8 54 54 40 00 00:03:23.597 WRITE FPDMA QUEUED 61 00 10 b8 53 54 40 00 00:03:23.597 WRITE FPDMA QUEUED Error 202 occurred at disk power-on lifetime: 9735 hours (405 days + 15 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 18 b8 51 54 40 00 00:03:23.349 WRITE FPDMA QUEUED 61 00 40 b8 56 54 40 00 00:03:23.347 WRITE FPDMA QUEUED 61 00 38 b8 55 54 40 00 00:03:23.347 WRITE FPDMA QUEUED 61 00 30 b8 54 54 40 00 00:03:23.347 WRITE FPDMA QUEUED 61 00 28 b8 53 54 40 00 00:03:23.347 WRITE FPDMA QUEUED Error 201 occurred at disk power-on lifetime: 9735 hours (405 days + 15 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 10 b8 50 54 40 00 00:03:23.098 WRITE FPDMA QUEUED 61 00 48 b8 58 54 40 00 00:03:23.097 WRITE FPDMA QUEUED 61 00 40 b8 56 54 40 00 00:03:23.097 WRITE FPDMA QUEUED 61 00 38 b8 55 54 40 00 00:03:23.097 WRITE FPDMA QUEUED 61 00 30 b8 54 54 40 00 00:03:23.097 WRITE FPDMA QUEUED Error 200 occurred at disk power-on lifetime: 9735 hours (405 days + 15 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 08 b8 50 54 40 00 00:03:22.348 WRITE FPDMA QUEUED 61 00 48 b8 59 54 40 00 00:03:22.347 WRITE FPDMA QUEUED 61 00 40 b8 58 54 40 00 00:03:22.347 WRITE FPDMA QUEUED 61 00 38 b8 56 54 40 00 00:03:22.347 WRITE FPDMA QUEUED 61 00 30 b8 55 54 40 00 00:03:22.347 WRITE FPDMA QUEUED Error 199 occurred at disk power-on lifetime: 9735 hours (405 days + 15 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 08 b8 58 54 40 00 00:03:22.030 WRITE FPDMA QUEUED 61 00 58 b8 57 54 40 00 00:03:22.028 WRITE FPDMA QUEUED 61 00 50 b8 56 54 40 00 00:03:22.028 WRITE FPDMA QUEUED 61 00 48 b8 55 54 40 00 00:03:22.028 WRITE FPDMA QUEUED 61 00 40 b8 54 54 40 00 00:03:22.028 WRITE FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 9718 - # 2 Short offline Completed without error 00% 9694 - # 3 Short offline Completed without error 00% 9670 - # 4 Short offline Completed without error 00% 9646 - # 5 Short offline Completed without error 00% 9604 - # 6 Short offline Completed without error 00% 9558 - # 7 Short offline Completed without error 00% 9534 - # 8 Short offline Completed without error 00% 9510 - # 9 Short offline Completed without error 00% 9454 - #10 Short offline Completed without error 00% 9290 - #11 Short offline Completed without error 00% 9140 - #12 Short offline Completed without error 00% 8972 - #13 Short offline Completed without error 00% 8804 - #14 Short captive Completed without error 00% 8629 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
root@Server:~ # smartctl -a /dev/da1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Se Device Model: WDC WD4000F9YZ-09N20L0 Serial Number: WD-WCC5D0023623 LU WWN Device Id: 5 0014ee 208ea4f01 Firmware Version: 01.01A01 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Jun 1 18:42:37 2019 MDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (42300) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 457) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 158 149 021 Pre-fail Always - 11091 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1489 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 048 048 000 Old_age Always - 38513 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1160 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 199 199 000 Old_age Always - 836 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 652 194 Temperature_Celsius 0x0022 099 099 000 Old_age Always - 53 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 184 000 Old_age Always - 159 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 15969 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 15969 occurred at disk power-on lifetime: 16506 hours (687 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 0c 00 00 00 00 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ef 03 0c 00 00 00 00 00 01:00:46.084 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:46.084 CHECK POWER MODE ec 00 00 00 00 00 00 00 01:00:46.083 IDENTIFY DEVICE ef 03 0c 00 00 00 00 00 01:00:45.834 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.834 CHECK POWER MODE Error 15968 occurred at disk power-on lifetime: 16506 hours (687 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 0c 00 00 00 00 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ef 03 0c 00 00 00 00 00 01:00:45.834 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.834 CHECK POWER MODE ec 00 00 00 00 00 00 00 01:00:45.833 IDENTIFY DEVICE ef 03 0c 00 00 00 00 00 01:00:45.584 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.584 CHECK POWER MODE Error 15967 occurred at disk power-on lifetime: 16506 hours (687 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 0c 00 00 00 00 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ef 03 0c 00 00 00 00 00 01:00:45.584 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.584 CHECK POWER MODE ec 00 00 00 00 00 00 00 01:00:45.584 IDENTIFY DEVICE ef 03 0c 00 00 00 00 00 01:00:45.418 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.418 CHECK POWER MODE Error 15966 occurred at disk power-on lifetime: 16506 hours (687 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 0c 00 00 00 00 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ef 03 0c 00 00 00 00 00 01:00:45.418 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.418 CHECK POWER MODE ec 00 00 00 00 00 00 00 01:00:45.334 IDENTIFY DEVICE ef 03 0c 00 00 00 00 00 01:00:45.085 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.085 CHECK POWER MODE Error 15965 occurred at disk power-on lifetime: 16506 hours (687 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 0c 00 00 00 00 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ef 03 0c 00 00 00 00 00 01:00:45.085 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.085 CHECK POWER MODE ec 00 00 00 00 00 00 00 01:00:45.085 IDENTIFY DEVICE ef 03 0c 00 00 00 00 00 01:00:45.085 SET FEATURES [Set transfer mode] e5 00 00 00 00 00 00 00 01:00:45.085 CHECK POWER MODE SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 38493 - # 2 Short offline Completed without error 00% 38469 - # 3 Short offline Completed without error 00% 38445 - # 4 Short offline Completed without error 00% 38421 - # 5 Short offline Completed without error 00% 38378 - # 6 Short offline Completed without error 00% 38332 - # 7 Short offline Completed without error 00% 38308 - # 8 Short offline Completed without error 00% 38284 - # 9 Short offline Completed without error 00% 38228 - #10 Short offline Completed without error 00% 38063 - #11 Short offline Completed without error 00% 37914 - #12 Short offline Completed without error 00% 37746 - #13 Short offline Completed without error 00% 37578 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
