kamal juck
- May 13, 2014
Hello, I'm bit of a newbie.
Today I got a new message that I don't understand. "Device: /dev/ada4, 80 Currently unreadable (pending) sectors"
Is the message informing me that there are 80 sectors that are unreadable? if so is that a lot? (doesn't seem like a lot on 3TB HHD).
On my system I have 9 physical drives in 3 vaults, it seems half of the drives have some type of SMART error, when I use the "smartctl' command. All of the drives are less then year old and were purchased in three lots as I grew my system. I don't know how much I should be concerned. (just in case I need to swap out the drive, I just ordered a replacement drive).
So can someone please point me to a "simple" explanation on how to understand this listing and error message. Or post a reply.
Thanks in advance.
K
the following is the listing from "smartctl'
Thanks in advance.
K
- [root@freenas] ~# smartctl -a /dev/ada4
- smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
- Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
- === START OF INFORMATION SECTION ===
- Model Family: Toshiba 3.5" HDD DT01ACA...
- Device Model: TOSHIBA DT01ACA300
- Serial Number: Y3UDK86GS
- LU WWN Device Id: 5 000039 ff4d3ccc4
- Firmware Version: MX6OABB0
- User Capacity: 3,000,592,982,016 bytes [3.00 TB]
- Sector Sizes: 512 bytes logical, 4096 bytes physical
- Rotation Rate: 7200 rpm
- Form Factor: 3.5 inches
- Device is: In smartctl database [for details use: -P show]
- ATA Version is: ATA8-ACS T13/1699-D revision 4
- SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
- Local Time is: Sat May 16 20:04:25 2015 EDT
- SMART support is: Available - device has SMART capability.
- SMART support is: Enabled
- === START OF READ SMART DATA SECTION ===
- SMART overall-health self-assessment test result: PASSED
- General SMART Values:
- Offline data collection status: (0x84) Offline data collection activity
- was suspended by an interrupting command from host.
- Auto Offline Data Collection: Enabled.
- Self-test execution status: ( 33) The self-test routine was interrupted
- by the host with a hard or soft reset.
- Total time to complete Offline
- data collection: (22078) seconds.
- capabilities: (0x5b) SMART execute Offline immediate.
- Auto Offline data collection on/off support.
- Suspend Offline collection upon new
- command.
- Offline surface scan supported.
- Self-test supported.
- No Conveyance Self-test supported.
- Selective Self-test supported.
- SMART capabilities: (0x0003) Saves SMART data before entering
- power-saving mode.
- Supports SMART auto save timer.
- Error logging capability: (0x01) Error logging supported.
- General Purpose Logging supported.
- Short self-test routine
- recommended polling time: ( 1) minutes.
- Extended self-test routine
- recommended polling time: ( 368) minutes.
- SCT capabilities: (0x003d) SCT Status supported.
- SCT Error Recovery Control supported.
- SCT Feature Control supported.
- SCT Data Table supported.
- SMART Attributes Data Structure revision number: 16
- Vendor Specific SMART Attributes with Thresholds:
- ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
- 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
- 2 Throughput_Performance 0x0005 140 140 054 Pre-fail Offline - 69
- 3 Spin_Up_Time 0x0007 177 177 024 Pre-fail Always - 337 (Average 311)
- 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 76
- 5 Reallocated_Sector_Ct 0x0033 091 091 005 Pre-fail Always - 334
- 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
- 8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
- 9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 7967
- 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
- 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 76
- 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 280
- 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 280
- 194 Temperature_Celsius 0x0002 153 153 000 Old_age Always - 39 (Min/Max 21/43)
- 196 Reallocated_Event_Count 0x0032 084 084 000 Old_age Always - 455
- 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 80
- 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
- 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
- SMART Error Log Version: 1
- ATA Error Count: 23 (device log contains only the most recent five errors)
- CR = Command Register [HEX]
- FR = Features Register [HEX]
- SC = Sector Count Register [HEX]
- SN = Sector Number Register [HEX]
- CL = Cylinder Low Register [HEX]
- CH = Cylinder High Register [HEX]
- DH = Device/Head Register [HEX]
- DC = Device Command Register [HEX]
- ER = Error register [HEX]
- ST = Status register [HEX]
- Powered_Up_Time is measured from power on, and printed as
- DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
- SS=sec, and sss=millisec. It "wraps" after 49.710 days.
- Error 23 occurred at disk power-on lifetime: 7812 hours (325 days + 12 hours)
- When the command that caused the error occurred, the device was active or idle.
- After command completion occurred, registers were:
- ER ST SC SN CL CH DH
- 40 51 58 a8 6a 79 0c Error: UNC at LBA = 0x0c796aa8 = 209283752
- Commands leading to the command that caused the error were:
- CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
- 60 00 00 00 6b 79 40 00 3d+21:24:07.350 READ FPDMA QUEUED
- 60 00 f8 00 6a 79 40 00 3d+21:24:04.245 READ FPDMA QUEUED
- 60 00 f0 00 69 79 40 00 3d+21:24:04.137 READ FPDMA QUEUED
- 60 00 e8 00 68 79 40 00 3d+21:24:03.696 READ FPDMA QUEUED
- 60 00 e0 00 67 79 40 00 3d+21:24:03.604 READ FPDMA QUEUED
- Error 22 occurred at disk power-on lifetime: 7812 hours (325 days + 12 hours)
- 40 51 e0 98 2e 79 0c Error: UNC at LBA = 0x0c792e98 = 209268376
- 60 00 58 78 2f 79 40 00 3d+21:23:45.781 READ FPDMA QUEUED
- 60 00 50 78 2e 79 40 00 3d+21:23:45.781 READ FPDMA QUEUED
- 2f 00 01 10 00 00 00 00 3d+21:23:45.709 READ LOG EXT
- 60 00 50 78 2f 79 40 00 3d+21:23:41.873 READ FPDMA QUEUED
- 60 00 48 78 2e 79 40 00 3d+21:23:41.873 READ FPDMA QUEUED
- Error 21 occurred at disk power-on lifetime: 7812 hours (325 days + 12 hours)
- 2f 00 01 10 00 00 00 00 3d+21:23:41.791 READ LOG EXT
- 60 00 48 78 2f 79 40 00 3d+21:23:34.852 READ FPDMA QUEUED
- 60 00 40 78 2e 79 40 00 3d+21:23:34.852 READ FPDMA QUEUED
- Error 20 occurred at disk power-on lifetime: 7812 hours (325 days + 12 hours)
- 2f 00 01 10 00 00 00 00 3d+21:23:34.778 READ LOG EXT
- 60 00 40 78 2f 79 40 00 3d+21:23:27.747 READ FPDMA QUEUED
- 60 00 38 78 2e 79 40 00 3d+21:23:27.747 READ FPDMA QUEUED
- Error 19 occurred at disk power-on lifetime: 7812 hours (325 days + 12 hours)
- 40 51 f0 88 2e 79 0c Error: UNC at LBA = 0x0c792e88 = 209268360
- 2f 00 01 10 00 00 00 00 3d+21:23:27.665 READ LOG EXT
- 60 00 38 78 2f 79 40 00 3d+21:23:21.211 READ FPDMA QUEUED
- 60 00 30 78 2e 79 40 00 3d+21:23:20.380 READ FPDMA QUEUED
- SMART Self-test log structure revision number 1
- Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
- # 1 Extended offline Interrupted (host reset) 10% 7960 -
- # 2 Short offline Completed without error 00% 7952 -
- # 3 Extended offline Completed without error 00% 7840 -
- # 4 Short offline Completed without error 00% 7832 -
- # 5 Extended offline Completed without error 00% 7720 -
- # 6 Short offline Completed without error 00% 7712 -
- # 7 Extended offline Completed without error 00% 7600 -
- # 8 Short offline Completed without error 00% 7592 -
- # 9 Extended offline Completed without error 00% 7480 -
- #10 Short offline Completed without error 00% 7472 -
- #11 Extended offline Completed without error 00% 7360 -
- #12 Short offline Completed without error 00% 7352 -
- #13 Extended offline Completed without error 00% 7240 -
- #14 Short offline Completed without error 00% 7232 -
- #15 Extended offline Completed without error 00% 7120 -
- #16 Short offline Completed without error 00% 7112 -
- #17 Extended offline Completed without error 00% 7000 -
- #18 Short offline Completed without error 00% 6992 -
- #19 Extended offline Completed without error 00% 6880 -
- #20 Short offline Completed without error 00% 6872 -
- #21 Extended offline Completed without error 00% 6856 -
- SMART Selective self-test log data structure revision number 1
- SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
- 1 0 0 Not_testing
- 2 0 0 Not_testing
- 3 0 0 Not_testing
- 4 0 0 Not_testing
- 5 0 0 Not_testing
- Selective self-test flags (0x0):
- After scanning selected spans, do NOT read-scan remainder of disk.
- If Selective self-test is pending on power-up, resume after 0 minute delay.
