adorobis
- Oct 16, 2017
Dear Experts,
Since several weeks I have recurring error in the log:
no other errors or issues existed. Since yesterday the following error has occured as well:
the console shows
and running smartctl for that drive:
Any suggestions what can be wrong? Or should I already replace the drive?
Thanks in advance for help!
Device: /dev/ada3, Read SMART Self-Test Log Failed
Device: /dev/ada3, Failed SMART usage Attribute: 1 Raw_Read_Error_Rate
the console shows
Nov 13 08:49:20 homeserwer (ada3:ata3:0:1:0): WRITE_DMA48. ACB: 35 00 30 d6 e0 40 c3 00 00 00 60 00 Nov 13 08:49:20 homeserwer (ada3:ata3:0:1:0): CAM status: ATA Status Error Nov 13 08:49:20 homeserwer (ada3:ata3:0:1:0): ATA status: 51 (DRDY SERV ERR), error: 84 (ICRC ABRT ) Nov 13 08:49:20 homeserwer (ada3:ata3:0:1:0): RES: 51 84 30 d6 e0 c3 c3 00 00 60 00 Nov 13 08:49:20 homeserwer (ada3:ata3:0:1:0): Retrying command, 3 more tries remain Nov 13 08:51:08 homeserwer (ada3:ata3:0:1:0): READ_DMA48. ACB: 25 00 40 97 01 40 63 01 00 00 08 00 Nov 13 08:51:08 homeserwer (ada3:ata3:0:1:0): CAM status: ATA Status Error Nov 13 08:51:08 homeserwer (ada3:ata3:0:1:0): ATA status: 51 (DRDY SERV ERR), error: 84 (ICRC ABRT ) Nov 13 08:51:08 homeserwer (ada3:ata3:0:1:0): RES: 51 84 40 97 01 63 63 01 00 08 00 Nov 13 08:51:08 homeserwer (ada3:ata3:0:1:0): Retrying command, 3 more tries remain Nov 13 09:00:19 homeserwer (ada3:ata3:0:1:0): READ_DMA48. ACB: 25 00 48 77 12 40 c4 00 00 00 58 00 Nov 13 09:00:19 homeserwer (ada3:ata3:0:1:0): CAM status: ATA Status Error Nov 13 09:00:19 homeserwer (ada3:ata3:0:1:0): ATA status: 51 (DRDY SERV ERR), error: 84 (ICRC ABRT ) Nov 13 09:00:19 homeserwer (ada3:ata3:0:1:0): RES: 51 84 48 77 12 c4 c4 00 00 58 00 Nov 13 09:00:19 homeserwer (ada3:ata3:0:1:0): Retrying command, 3 more tries remain Nov 13 09:02:51 homeserwer (ada3:ata3:0:1:0): WRITE_DMA48. ACB: 35 00 38 cd ae 40 e2 00 00 00 10 00 Nov 13 09:02:51 homeserwer (ada3:ata3:0:1:0): CAM status: ATA Status Error Nov 13 09:02:51 homeserwer (ada3:ata3:0:1:0): ATA status: 51 (DRDY SERV ERR), error: 84 (ICRC ABRT ) Nov 13 09:02:51 homeserwer (ada3:ata3:0:1:0): RES: 51 84 38 cd ae e2 e2 00 00 10 00 Nov 13 09:02:51 homeserwer (ada3:ata3:0:1:0): Retrying command, 3 more tries remain Nov 13 09:13:01 homeserwer (ada3:ata3:0:1:0): READ_DMA48. ACB: 25 00 b8 5d b5 40 c3 00 00 00 58 00 Nov 13 09:13:01 homeserwer (ada3:ata3:0:1:0): CAM status: ATA Status Error Nov 13 09:13:01 homeserwer (ada3:ata3:0:1:0): ATA status: 51 (DRDY SERV ERR), error: 84 (ICRC ABRT ) Nov 13 09:13:01 homeserwer (ada3:ata3:0:1:0): RES: 51 84 b8 5d b5 c3 c3 00 00 58 00 Nov 13 09:13:01 homeserwer (ada3:ata3:0:1:0): Retrying command, 3 more tries remain
root@homeserwer:~ # smartctl -a /dev/ada3 smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RC3 amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68N32N0 Serial Number: WD-WCC7K3NR31XY LU WWN Device Id: 5 0014ee 2648cbb70 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri Nov 13 09:17:05 2020 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 39) The self-test routine was interrupted by the host with a hard or soft reset. Total time to complete Offline data collection: (44520) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 472) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 168 167 021 Pre-fail Always - 6591 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 118 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 067 067 000 Old_age Always - 24529 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 118 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 76 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 75 194 Temperature_Celsius 0x0022 110 104 000 Old_age Always - 40 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 198 000 Old_age Always - 223775 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Interrupted (host reset) 70% 24496 - # 2 Extended offline Interrupted (host reset) 70% 24329 - # 3 Extended offline Completed without error 00% 24168 - # 4 Extended offline Completed without error 00% 23999 - # 5 Extended offline Completed without error 00% 23831 - # 6 Extended offline Completed without error 00% 23664 - # 7 Extended offline Completed without error 00% 23498 - # 8 Extended offline Completed without error 00% 23330 - # 9 Extended offline Completed without error 00% 23162 - #10 Extended offline Completed without error 00% 22995 - #11 Extended offline Completed without error 00% 22827 - #12 Extended offline Completed without error 00% 22659 - #13 Extended offline Completed without error 00% 22491 - #14 Extended offline Completed without error 00% 22325 - #15 Extended offline Completed without error 00% 22157 - #16 Extended offline Completed without error 00% 21989 - #17 Extended offline Completed without error 00% 21820 - #18 Extended offline Completed without error 00% 21653 - #19 Extended offline Completed without error 00% 21486 - #20 Extended offline Completed: read failure 50% 21311 3212679328 #21 Extended offline Completed: read failure 50% 21143 3212679328 2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 3 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
