Unrecoverable read error and 128K repaired during scrub, but no known data errors
CoteRL
On Nov 1st I noticed a few entries in the log saying there was an unrecoverable read error as well as the scrub status of that pool stating 128K was repaired. However, there don't seem to be any other indications of issues with the disk or pool. Is there any way I can track down what caused it and find out if there are other issues I should be worried about?
The system is running FreeNAS-9.10.1-U2 (f045a8b) and is using ECC memory.
Entry in the event log:
Nov  1 07:08:12 nas (da7:mps0:0:15:0): READ(10). CDB: 28 00 91 9c 3b 90 00 01 00 00
Nov  1 07:08:12 nas (da7:mps0:0:15:0): CAM status: CCB request completed with an error
Nov  1 07:08:12 nas (da7:mps0:0:15:0): Retrying command
Nov  1 07:08:12 nas (da7:mps0:0:15:0): READ(10). CDB: 28 00 91 9c 3a 90 00 01 00 00
Nov  1 07:08:12 nas (da7:mps0:0:15:0): CAM status: SCSI Status Error
Nov  1 07:08:12 nas (da7:mps0:0:15:0): SCSI status: Check Condition
Nov  1 07:08:12 nas (da7:mps0:0:15:0): SCSI sense: MEDIUM ERROR asc:11,0 (Unrecovered read error)
Nov  1 07:08:12 nas (da7:mps0:0:15:0): Info: 0x919c3a90
Nov  1 07:08:12 nas (da7:mps0:0:15:0): Error 5, Unretryable error
zpool status
pool: tank
 state: ONLINE
  scan: scrub repaired 128K in 3h17m with 0 errors on Tue Nov  1 07:17:25 2016
		NAME											STATE	 READ WRITE CKSUM
		tank											ONLINE	   0	 0	 0
		  mirror-0									  ONLINE	   0	 0	 0
			gptid/2b6dc7a2-7c07-11e6-bd2c-a0369f6ae424  ONLINE	   0	 0	 0
			gptid/2c0f957f-7c07-11e6-bd2c-a0369f6ae424  ONLINE	   0	 0	 0
		  mirror-1									  ONLINE	   0	 0	 0
			gptid/2cafa959-7c07-11e6-bd2c-a0369f6ae424  ONLINE	   0	 0	 0
			gptid/2d5120e4-7c07-11e6-bd2c-a0369f6ae424  ONLINE	   0	 0	 0
		  mirror-2									  ONLINE	   0	 0	 0
			gptid/2dee9b44-7c07-11e6-bd2c-a0369f6ae424  ONLINE	   0	 0	 0
			gptid/2e86f715-7c07-11e6-bd2c-a0369f6ae424  ONLINE	   0	 0	 0
		  mirror-3									  ONLINE	   0	 0	 0
			gptid/d8f0cacf-7deb-11e6-aebb-a0369f6ae424  ONLINE	   0	 0	 0
			gptid/dc295780-7deb-11e6-aebb-a0369f6ae424  ONLINE	   0	 0	 0
		  mirror-4									  ONLINE	   0	 0	 0
			gptid/e5624a6b-7deb-11e6-aebb-a0369f6ae424  ONLINE	   0	 0	 0
			gptid/e8a29f2a-7deb-11e6-aebb-a0369f6ae424  ONLINE	   0	 0	 0
		  mirror-5									  ONLINE	   0	 0	 0
			gptid/f215ae1b-7deb-11e6-aebb-a0369f6ae424  ONLINE	   0	 0	 0
			gptid/f560e153-7deb-11e6-aebb-a0369f6ae424  ONLINE	   0	 0	 0
errors: No known data errors
SMART report for da7
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red Pro
Device Model:	 WDC WD3001FFSX-68JNUN0
Serial Number:	<redacted>
LU WWN Device Id: 5 0014ee 0aea96dda
Firmware Version: 81.00A81
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sun Nov  6 14:31:36 2016 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(30780) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 334) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x70bd) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   150   150   021	Pre-fail  Always	   -	   11500
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   26
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   084   084   000	Old_age   Always	   -	   11942
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   26
 16 Unknown_Attribute	   0x0022   255   000   000	Old_age   Always	   -	   8518296030954
183 Runtime_Bad_Block	   0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   25
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   33
194 Temperature_Celsius	 0x0022   119   108   000	Old_age   Always	   -	   33
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 11906		 -
# 2  Extended offline	Completed without error	   00%	 11858		 -
# 3  Short offline	   Completed without error	   00%	 11666		 -
# 4  Extended offline	Completed without error	   00%	 11577		 -
# 5  Short offline	   Completed without error	   00%	 11499		 -
# 6  Short offline	   Completed without error	   00%	 11331		 -
# 7  Extended offline	Completed without error	   00%	 11242		 -
# 8  Short offline	   Completed without error	   00%	 11163		 -
# 9  Short offline	   Completed without error	   00%	 10947		 -
#10  Extended offline	Completed without error	   00%	 10660		 -
#11  Conveyance offline  Completed without error	   00%	 10654		 -
#12  Short offline	   Completed without error	   00%	 10654		 -
#13  Short offline	   Completed without error	   00%	 10611		 -
#14  Extended offline	Completed without error	   00%	 10523		 -
#15  Short offline	   Completed without error	   00%	 10443		 -
#16  Short offline	   Completed without error	   00%	 10204		 -
#17  Extended offline	Completed without error	   00%	 10117		 -
#18  Short offline	   Completed without error	   00%	 10036		 -
#19  Short offline	   Completed without error	   00%	  9868		 -
#20  Extended offline	Completed without error	   00%	  9780		 -
#21  Short offline	   Completed without error	   00%	  9708		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ZFS says everything is fine, so everything is probably fine.
SMART data looks fine, so I'd guess it was probably a cable issue. What's the storage topology?
CoteRL
It's a all in a Supermicro CSE-836E26-R1200B which has the 16 slot SAS2 Expander backplane BPN-SAS2-836EL. Currently since I'm running SATA disks and can't use SAS multipathing it's connected by a single SFF8087 cable to the IBM M1015.
Well, that rules out obvious cabling issues.
Keep an eye on it for now.
Stux
If it happens again to the same disk, swap the disk around with another and see if the issue stays with the bay or follows the disk.
Seems like it may be a once off.
Thank ZFS for detecting, handling and fixing the error.
CoteRL
Ok, thanks for the replies. I'll just monitor it for now. I just wanted to make sure I wasn't missing something obvious.
