monkeybutt
- Dec 10, 2016
Been getting some troubling Critical Alerts lately.
Also getting this every so often in my security run output.
Am I about to lose a drive?
EDIT: Smart test results for this drive:
Device: /dev/ada3, 1 Currently unreadable (pending) sectors
Device: /dev/ada3, Self-Test Log error count increased from 7 to 8
freenas.local kernel log messages: > (ada3:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 c8 01 40 40 00 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) > (ada3:ahcich3:0:0:0): RES: 41 10 c8 01 40 40 00 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 9e fb 40 ae 00 00 01 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) > (ada3:ahcich3:0:0:0): RES: 41 10 30 9e fb 40 ae 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 e0 e0 17 fc 40 ae 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) > (ada3:ahcich3:0:0:0): RES: 41 10 e0 17 fc 40 ae 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 90 01 40 40 00 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) > (ada3:ahcich3:0:0:0): RES: 41 10 90 01 40 40 00 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command
freenas.local kernel log messages: > (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 e8 e9 40 dc 00 00 01 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) > (ada3:ahcich3:0:0:0): RES: 41 40 e0 e8 e9 40 dc 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 80 e8 50 2a 40 45 01 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) > (ada3:ahcich3:0:0:0): RES: 41 40 e8 50 2a 40 45 01 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 80 90 ce 67 40 db 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) > (ada3:ahcich3:0:0:0): RES: 41 40 90 ce 67 40 db 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 80 f0 1f 41 40 dd 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) > (ada3:ahcich3:0:0:0): RES: 41 40 f0 1f 41 40 dd 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 80 90 f5 75 40 dd 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) > (ada3:ahcich3:0:0:0): RES: 41 40 90 f5 75 40 dd 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command > (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 80 90 76 01 40 dd 00 00 00 00 00 > (ada3:ahcich3:0:0:0): CAM status: ATA Status Error > (ada3:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) > (ada3:ahcich3:0:0:0): RES: 41 40 90 76 01 40 dd 00 00 00 00 > (ada3:ahcich3:0:0:0): Retrying command
[root@freenas] ~# smartctl -a /dev/ada3 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCC4E2ZRALPS LU WWN Device Id: 5 0014ee 20dcbd767 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Dec 15 09:39:01 2017 CST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 113) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (50580) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 506) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 107 3 Spin_Up_Time 0x0027 177 174 021 Pre-fail Always - 8141 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 18 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8659 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 18 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 6 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 111 194 Temperature_Celsius 0x0022 123 112 000 Old_age Always - 29 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 5 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 10% 8581 28010584 # 2 Extended offline Completed: read failure 90% 8485 36709488 # 3 Short offline Completed: read failure 10% 8422 36706080 # 4 Short offline Completed: read failure 90% 8206 36709704 # 5 Extended offline Completed: read failure 90% 8110 36709704 # 6 Short offline Completed: read failure 90% 8038 36709704 # 7 Short offline Completed: read failure 90% 7870 36709704 # 8 Extended offline Completed: read failure 90% 7774 36709704 # 9 Short offline Completed without error 00% 7703 - #10 Extended offline Completed: read failure 90% 7670 36709704 #11 Short offline Completed without error 00% 7462 - #12 Extended offline Completed without error 00% 7375 - #13 Short offline Completed without error 00% 7294 - #14 Short offline Completed without error 00% 7126 - #15 Extended offline Completed without error 00% 7040 - #16 Short offline Completed without error 00% 6958 - #17 Short offline Completed without error 00% 6743 - #18 Extended offline Completed without error 00% 6656 - #19 Short offline Completed without error 00% 6575 - #20 Short offline Completed without error 00% 6407 - #21 Extended offline Completed without error 00% 6320 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@freenas] ~#
