I put together a little system to run as a fileserver/media player, here are the specs:
Intel Core i3 6100 Boxed
ASUS B150M-C
G.Skill Ripjaws IV 8GB DDR4-2133 CL15 kit
Crucial BX100 120GB
Seagate Desktop HDD 4TB x2
The problem is that when i try to boot from USB (usb 2.0 key in a 2.0 slot), I get this error:
Mounting from ufs:/dev/ufs/FreeNASs1a failed with error 19
I googled around a little bit and found out that this error is quite common. The most common solution for this problem seems to be to insert these lines in the loader prompt:
set debug.acpi.disabled="hostres"
boot
I did this but the problem still remains.
Could someone please advise me what to do next?
I must warn you that i'm completely new to freenas and working with comman lines.
Thanks!
ASUS B150M-C
Crucial BX100 120GB
boot
Thanks!
