Idan Presser
- Jan 18, 2016
Hi guys!
I'm new to the forums and this is my first time installing FreeNAS, but I've built a few servers over the years and know my way around a computer...
Like many others before me, I've encountered the dreaded error 19 during install, I'll walk you through what I've tried so far, but first here are the rig specs:
Gigabyte GA-B150M-HD3
Intel Pentium G4400
G.Skill 8GB DDR3 (run clean 10 memtest cycles)
WD red 3TB x 6
SanDisk cruzer fit 16GB
I've started by burning the 9.3.1 STABLE 64bit ISO (SHA256 verified) onto a 32GB cruzer pop. received error 19 and started digging through the forums.
I'm close to giving up and settling on an old Debian distro, but I want ZFS...
Please help!
EDIT: made it a bit more legible
Intel Pentium G4400
WD red 3TB x 6
- First I've disabled XHCI and fast booting -> Error 19.
- Then moved the two disk-on-keys to USB2 ports -> Error 19.
- Then reformatted the pop and reburned the ISO -> Error 19.
- Then "zeroed" the pop using DD -> Error 19.
- Then tried to add "set debug.acpi.disabled="hostres"" to the loader -> Error 19.
- Then tired 3 more disk-on-keys, formatted, zeroed, burned -> Error 19.
- Then found an old external cd-rom, burned the image to a disk, booted -> Error 19.
- Then downloaded and verified 9.3 release, burned to CD -> Error 19.
- Tried to mount the CD using cd9690:/dev/acd0 ro, cd9690:/dev/cd0 ro, cd9690:/dev/acd0, etc.
- Tried to boot from CD and mount from DoK, boot from DoK and mount the CD, but Error 19...
- I even tried to disable the onboard LAN (Realtek unfortunately) although I'm quite certain it has nothing to do with the mounting error.
Please help!
