I am downloaded the FreeNAS-8.3.0-Release-x64.iso and burned it onto a CD. Booted from the CD and installed the FreeNAS onto a usb stick.
On booting from the usb stick, I get the following errors... I found this link with the same error mentioned - http://forums.freenas.org/archive/index.php/t-3189.html (at the end, it is redirected to another link - http://forums.freenas.org/showthread.php?4278-USB-3-0-Part-II&p=16336&viewfull=1#post16336 which talks about enabled usb3.0 support --- how do I update loader.conf file from the prompt,,, what file editing capabilities are available?)
Or is there any other solution to this problem.
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ROOT MOUNT ERROR:
If you have invalid mount options, reboot, and first try the following from
the loader prompt:
set vfs.root.mountfrom.options=rw
and then remove invalid mount options from /etc/fstab.
Loader variables:
vfs.root.mountfrom=ufs:/dev/ufs/FreeNASs1a
vfs.root.mountfrom.options=ro
Manual root filesystem specification:
<fstype>:<device> Mount <device> using filesystem <fstype>
eg. ufs:/dev/da0s1a
eg. cd9660:/dev/acd0
This is equivalent to: mount -t cd9660 /dev/acd0 /
ROOT MOUNT ERROR:
the loader prompt:
Loader variables:
eg. ufs:/dev/da0s1a
