I'm new at Freenas and I've already installed 3 systems with this great product, but recently I had to re-install freenas but after the first boot some error occurred and freenas won't boot.
The error messages is:
GEOM: ada0: the primary GPT partiton table is corrupt or invalid.
GEOM: ada0: using the secondary instead -- recovery strongly advised.
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ROOT MOUNT ERROR:
If you have invalid mount points, reboot, and first try the following from the loader prompt:
set vfs.root.mountfrom.options=rw
and then remove invalid mount options from etc/fstab.
Loader variables:
vfs.root.mountfrom=ufs:/dev/ufs/FreeNASs1a
vfs.root.mountfrom.options.ro
Manual root filesystem specification:
mountroot>
I really don't know how to proceed to solve this problem but have already take the disk to another system, deleted all partitions, re-installed several times but error is always happening.
Could someone give me an hint to solve this.
Regards,
Cristiano.
ROOT MOUNT ERROR:
Loader variables:
mountroot>
Regards,
Cristiano.
