Encryption Issue - No access and can't reset
robinmorgan
Upgraded to TrueNas from 11.2. Drive encryption has gone whack. If I try and extend the pool I get passphrase request. Entered my normal passphrase, didn't work. So I've tried to reset the keys. I'm in a jam...
Error Message:
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/encryption_freebsd.py", line 129, in rekey
    await self.middleware.call('disk.geli_rekey', pool)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1206, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/disk_/encryption_freebsd.py", line 159, in geli_rekey
    raise CallError(f'Unable to set key: {error}')
middlewared.service_exception.CallError: [EFAULT] Unable to set key: [EFAULT] Unable to set passphrase on gptid/4ef2e885-f835-11ea-821b-2c44fd842e10: geli: Cannot read passphrase: Inappropriate ioctl for device.
Samuel Tai
You'll have to reboot back into 11.2, if you've not upgraded your ZFS version yet, to expand your pool. TrueNAS 12 no longer allows GELI operations, only native ZFS encryption.
robinmorgan
I prefer not to reboot back into 11.2... how can I upgrade my ZFS? Would you recommend I roll back to 11.2 permanently, we are still suffering from half speed read and writes with a SCSI issue. I'm loosing faith.
Samuel Tai
If this is production critical, roll back to 11.2 to expand your pool, and then upgrade to 11.3U5, which is still stable. Note the caveats with the 11.3 upgrade before you pull the trigger, though.
robinmorgan
Thank you so much for the help. Can I assume they are working on the issue?
Samuel Tai
GELI is in the process of being deprecated. There is some discussion of adding tools for migration to native ZFS encryption, but for now the only method is ZFS send/receive from an unlocked GELI pool to a new ZFS native-encrypted pool.
robinmorgan
Thank you again. I have taken your advice and have rolled back. I am now getting a failed decrypt.
[EFAULT] Pool could not be imported: 30 devices failed to decrypt.
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/local/lib/python3.7/concurrent/futures/process.py", line 239, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 97, in main_worker
    res = loop.run_until_complete(coro)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 53, in _run
    return await self._call(name, serviceobj, methodobj, params=args, job=job)
  File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 45, in _call
    return methodobj(*params)
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 390, in import_pool
    'Failed to mount datasets after importing "%s" pool: %s', name_or_guid, str(e), exc_info=True
  File "libzfs.pyx", line 369, in libzfs.ZFS.__exit__
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 380, in import_pool
    raise CallError(f'Pool {name_or_guid} not found.', errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Pool 5541826905007370100 not found.
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/pool.py", line 1661, in unlock
    'cachefile': ZPOOL_CACHE_FILE,
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1141, in call
    app=app, pipes=pipes, job_on_progress_cb=job_on_progress_cb, io_thread=True,
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1081, in _call
    return await self._call_worker(name, *args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1101, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1036, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1010, in run_in_executor
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
    await self.future
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 386, in __run_body
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/pool.py", line 1673, in unlock
    raise CallError(msg)
middlewared.service_exception.CallError: [EFAULT] Pool could not be imported: 30 devices failed to decrypt.
Samuel Tai
Ugh. Do you have a recovery key available to unlock? If not, then you're out of luck.
robinmorgan
Yes I do!! I have all of them catalogued. I get the same error whilst using the key also!
Samuel Tai
Did you upgrade your pool in 12? If so, then there's no way to go back. Your only option now is to destroy and rebuild your pool from backup.
robinmorgan
Right, ok. What a mess.
robinmorgan
So I'm back on 12-1U, my pool is unlocked and working as it was. Can IO confirm something, I am unable to expand the pool yet I am able to access it. I did reset (removed) encryption before upgrading to 12. I'm confused why I have this issue.
Samuel Tai
How did you remove encryption before upgrading? Did you use @Patrick M. Hausen's procedure? Or did you just reset GELI? A reset only generates new keys, and doesn't remove encryption. When you run zpool status do your pool members have a .eli suffix?
robinmorgan
I believe I used the GELI... I do get the .Eli suffix.
zpool status
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:00:32 with 0 errors on Thu Jan 14 03:45:36 2021
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
        da0p2       ONLINE       0     0     0
errors: No known data errors
pool: tank1
state: ONLINE
scan: scrub repaired 0B in 1 days 02:46:40 with 0 errors on Sun Jan  3 02:46:43 2021
        tank1                                               ONLINE       0     0     0
          raidz2-0                                          ONLINE       0     0     0
            gptid/5bb8c482-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5c963e5b-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5c284a9c-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5bf57807-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5d388caa-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5e4cee32-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5e6af86b-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
          raidz2-1                                          ONLINE       0     0     0
            gptid/5c74676d-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5c2b09d7-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5ce451f5-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5dfd9c18-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5e9f7cd8-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5f5d5bf8-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
            gptid/5f2eae67-c217-11ea-ae35-2c44fd842e10.eli  ONLINE       0     0     0
          raidz2-3                                          ONLINE       0     0     0
            gptid/171fe6c0-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
            gptid/16e1a84a-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
            gptid/16c27717-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
            gptid/19637f86-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
            gptid/1a1fa8ed-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
            gptid/19d169e0-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
            gptid/1a03f3f5-0cea-11eb-b4f4-a0369f3909fe.eli  ONLINE       0     0     0
        logs
          gptid/d0ddf781-de10-11ea-9899-2c44fd842e10.eli    ONLINE       0     0     0
Samuel Tai
Did your paste get cut off? The last gptid was truncated.
robinmorgan
Sorry yes, now updated
Samuel Tai
OK, the reset explains why the recovery key didn't work, as the reset creates new keys, which invalidate the old keys/passphrases. I think the safest option for you is to destroy your pool, reboot into 11.2, reload your pool from backup, making sure it's unencrypted, and then upgrade to 11.3U5.
robinmorgan
Hello again, I’m still a little lost. My pool has around 80TB of data, deleting everything and pulling it back from backup is going to be timely and expensive. I felt I was meticulous in the upgrade and followed all the official literature. Now, here I am with apparently with one option “reload from backup”. Have I missed something?
Samuel Tai
Yes, you misapprehended a GELI reset as a removal of encryption. It’s actually a deletion of all the old keys and generation of new keys, which invalidates any prior GELI passphrases and recovery keys, so the absolute next step you should’ve done was to re-establish your passphrase and set a new recovery key. Unfortunately, as you didn’t do that, your only recourse is to rebuild.
robinmorgan
Ok, thank you again. To confirm, encryption is always open. I can restart the server and the pool is unlocked. As confirmed I am unable to add a new passphrase or extend the pool.
Just for my complete understanding; what should I have done before upgrading? Is there a step by step?
I am assuming I should have re-established my passphrase after upgrade of OS but before upgrading the ZFS.
