T_Haggerty
- Nov 3, 2020
System Info:
TrueNAS-12.0-RC1
Dell R620
32 gb RAM
Intel(R) Xeon(R) CPU E5520 @ 2.27GHz
Using a Netapp DS2246 connected via iSCSI, have 7 drives working, getting an error with 14 others when trying to format or add to the pool. Tried a few things I have found in other posts but have not had any luck, any tips or advice would be appreciated,
[EFAULT] Failed to wipe disk da9: [EFAULT] Command dd if=/dev/zero of=/dev/da9 bs=1M count=32 failed (code 1): dd: /dev/da9: Invalid argument 1+0 records in 0+0 records out 0 bytes transferred in 0.000830 secs (0 bytes/sec)
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
await self.future
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 397, in __run_body
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool.py", line 816, in do_update
enc_disks = await self.middleware.call('pool.format_disks', job, disks, {'enc_keypath': enc_keypath})
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1233, in call
return await self._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1191, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1202, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1106, in run_in_executor
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/disk_/format.py", line 25, in format
raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da9: [EFAULT] Command dd if=/dev/zero of=/dev/da9 bs=1M count=32 failed (code 1):
1+0 records in
0+0 records out
TrueNAS-12.0-RC1
Dell R620
32 gb RAM
await self.future
1+0 records in
0+0 records out
