Patrick M. Hausen
Dedicated Sage
- Nov 25, 2013
Hi, all,
my first post - I have a little procedure to share. I successfully removed the geli encryption from a live ZFS pool in FreeNAS 9.1.1 with the following steps:
0. Make sure you either have a separate backup of your data, or are willing to take the risk of losing everything. Second, please do not blindly follow these instructions if you do not know what you are doing. Third, the procedure works on one disk at a time. So if you run a RAIDZ2, you should be sufficiently safe. I would not dare to do this with data I need on a RAID1 or mirror. Nuff said ... let's start.
1. Scrub your pool to make sure all disks are in good condition.
2. Get the IDs of your zpool's devices:
[root@freenas-pmh] ~# zpool status
pool: zfs
state: ONLINE
NAME STATE READ WRITE CKSUM
zfs ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/b4a21304-8ec4-11e2-a224-28924a2bff32.eli ONLINE 0 0 0
gptid/b4f40dbd-8ec4-11e2-a224-28924a2bff32.eli ONLINE 0 0 0
gptid/b5527faa-8ec4-11e2-a224-28924a2bff32.eli ONLINE 0 0 0
gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32.eli ONLINE 0 0 0
errors: No known data errors
3. Start with the first disk - take offline and remove geli:
[root@freenas-pmh] ~# zpool offline zfs gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32.eli
[root@freenas-pmh] ~# geli detach gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32.eli
pool: zfs
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
zfs DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
5939868321408276145 OFFLINE 0 0 0 was /dev/gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32.eli
4. Replace formerly encrypted device with unencrypted one:
[root@freenas-pmh] ~# zpool replace zfs 5939868321408276145 gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32
replacing-3 OFFLINE 0 0 0
gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32 ONLINE 0 0 0 (resilvering)
5. Remove information about encryption from FreeNAS' config database
I'm not quite sure if this is strictly necessary. I did it, and it definitely did not hurt. FreeNAS keeps track of which devices are encrypted. So I wanted to make sure it treats the disks correctly.
[root@freenas-pmh] ~# /usr/local/bin/sqlite3 /data/freenas-v1.db "delete from storage_encrypteddisk where encrypted_provider = 'gptid/b5ae2aed-8ec4-11e2-a224-28924a2bff32';"
6. Wait for the resilvering to finish
7. Repeat 2. - 6. for each remaining disk. In the end your pool should look like this:
pool: zfs
state: ONLINE
zfs ONLINE 0 0 0
gptid/b4a21304-8ec4-11e2-a224-28924a2bff32 ONLINE 0 0 0
gptid/b4f40dbd-8ec4-11e2-a224-28924a2bff32 ONLINE 0 0 0
gptid/b5527faa-8ec4-11e2-a224-28924a2bff32 ONLINE 0 0 0
Note the absence of ".eli" from the device IDs. Check, if there are any entries left in the config database for encrypted disks:
[root@freenas-pmh] ~# /usr/local/bin/sqlite3 /data/freenas-v1.db "select * from storage_encrypteddisk;"
8. Stop all sharing services depending on the ZFS volume
9. Detach volume from the GUI - double check not to mark disks as new (i.e. erase them)
10. Reboot
11. Auto-import volume, restart sharing services
12. Done
Kind regards
Patrick
pool: zfs
state: ONLINE
zfs ONLINE 0 0 0
pool: zfs
state: DEGRADED
degraded state.
'zpool replace'.
zfs DEGRADED 0 0 0
pool: zfs
state: ONLINE
zfs ONLINE 0 0 0
10. Reboot
12. Done
Kind regards
Patrick
