wtfuar
- Jun 25, 2013
Nov 24 18:15:22 freenas kernel: FreeBSD 9.1-STABLE #0 r+16f6355: Tue Aug 27 00:38:40 PDT 2013
[root@freenas] ~# zpool status
pool: zfs1
state: ONLINE
status: The pool is formatted using a legacy on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on software that does not support feature
flags.
scan: resilvered 1.25T in 12h32m with 0 errors on Sat Aug 24 07:37:39 2013
NAME STATE READ WRITE CKSUM
zfs1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/27c029db-0c16-11e3-b6f5-002215ab012f.eli ONLINE 0 0 0
gptid/622428ec-9d54-11e2-9312-000c29cec408.eli ONLINE 0 0 0
gptid/634a7ede-9d54-11e2-9312-000c29cec408.eli ONLINE 0 0 0
gptid/64712091-9d54-11e2-9312-000c29cec408.eli ONLINE 0 0 0
gptid/65977639-9d54-11e2-9312-000c29cec408.eli ONLINE 0 0 0
gptid/66bc5d54-9d54-11e2-9312-000c29cec408.eli ONLINE 0 0 0
raidz2-1 ONLINE 0 0 0
gptid/c3f1ecf4-52d1-11e3-90c3-002215ab012f.eli ONLINE 0 0 0
gptid/c68231a2-52d1-11e3-90c3-002215ab012f.eli ONLINE 0 0 0
gptid/c9180ca3-52d1-11e3-90c3-002215ab012f.eli ONLINE 0 0 0
gptid/cbb5eb1e-52d1-11e3-90c3-002215ab012f.eli ONLINE 0 0 0
gptid/ce53bf90-52d1-11e3-90c3-002215ab012f.eli ONLINE 0 0 0
gptid/d0d662bc-52d1-11e3-90c3-002215ab012f.eli ONLINE 0 0 0
errors: No known data errors
raidz2-1 was added last week. The zfs pool was encrypted.
After I restarted freenas the pool was already decrypted! ^^
What happened here? Does something went wrong? Is the volume after I extended the pool permanently decrypted?
How do get the pool encrypted?
