I would still like to have an option to store the encryption secret in the FreeNAS configuration and automount everything on boot.
You can do that now. Just don't set a password on your encrypted volume.
I'm on 11.1 and need to decrypt an entire pool. Can anyone confirm that this procedure still the most uptodate?
root@freenas-pmh[~]# /usr/local/bin/sqlite3 /data/freenas-v1.db ".schema storage_encrypteddisk"
CREATE TABLE IF NOT EXISTS "storage_encrypteddisk" ("id" integer PRIMARY KEY, "encrypted_volume_id" integer NOT NULL, "encrypted_disk_id" varchar(100) NULL, "encrypted_provider" varchar(120) NOT NULL UNIQUE);No I did not. I postponed until Xmas time as I'll have plenty of time to do this properly without any time pressure.Did you proceed with removing the encryption on your drives?
I am on 11.2-U6 and want to do the same.
Looks like the structure in the sqlite database is still the same:
Code:root@freenas-pmh[~]# /usr/local/bin/sqlite3 /data/freenas-v1.db ".schema storage_encrypteddisk" CREATE TABLE IF NOT EXISTS "storage_encrypteddisk" ("id" integer PRIMARY KEY, "encrypted_volume_id" integer NOT NULL, "encrypted_disk_id" varchar(100) NULL, "encrypted_provider" varchar(120) NOT NULL UNIQUE);
So yes, it should work.
Proceed with caution ;)
Patrick
pool: Storage2
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0B in 04:22:56 with 0 errors on Sun Dec 20 04:22:56 2020
NAME STATE READ WRITE CKSUM
Storage2 DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9.eli OFFLINE 0 0 0
gptid/544b72c5-5f13-11ea-beeb-d43d7e3724e9.eli ONLINE 0 0 0
gptid/551dead0-5f13-11ea-beeb-d43d7e3724e9.eli ONLINE 0 0 0
errors: No known data errorsgpart list, please.I see the difference you mean, but you should just be able to use the gptid (not specifically tested by me, so check that first before using on a pool with real data you care about) instead of the ID shown in the original process.I made it to the point where I removed encryption from the first disk (geli detach gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9.eli) but it never gave me a new ID for the disk (here's the zpool status for that pool)
zpool replace Storage2 gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9.eli gptid/some-other-gptid-from-your-partitionroot@freenas[~]# gpart list da3 Geom name: da3 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7814037127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,543a65ff-5f13-11ea-beeb-d43d7e3724e9,0x80,0x400000) rawuuid: 543a65ff-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da3p2 Mediasize: 3998639460352 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,544b72c5-5f13-11ea-beeb-d43d7e3724e9,0x400080,0x1d180be08) rawuuid: 544b72c5-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: da3 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 root@freenas[~]# gpart list da4 Geom name: da4 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7814037127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da4p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,536c3218-5f13-11ea-beeb-d43d7e3724e9,0x80,0x400000) rawuuid: 536c3218-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da4p2 Mediasize: 3998639460352 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,537d9fec-5f13-11ea-beeb-d43d7e3724e9,0x400080,0x1d180be08) rawuuid: 537d9fec-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: da4 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 root@freenas[~]# gpart list da5 Geom name: da5 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7814037127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da5p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,550c025b-5f13-11ea-beeb-d43d7e3724e9,0x80,0x400000) rawuuid: 550c025b-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da5p2 Mediasize: 3998639460352 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,551dead0-5f13-11ea-beeb-d43d7e3724e9,0x400080,0x1d180be08) rawuuid: 551dead0-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: da5 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3
Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 234441607 first: 40 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 524288 (512K) Sectorsize: 512 Stripesize: 0 Stripeoffset: 20480 Mode: r0w0e0 efimedia: HD(1,GPT,6e0865cd-87be-11e8-b421-d43d7e3724e9,0x28,0x400) rawuuid: 6e0865cd-87be-11e8-b421-d43d7e3724e9 rawtype: 83bd6b9d-7f41-11dc-be0b-001560b84f0f label: (null) length: 524288 offset: 20480 type: freebsd-boot index: 1 end: 1063 start: 40 2. Name: ada0p2 Mediasize: 120033558528 (112G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 544768 Mode: r1w1e1 efimedia: HD(2,GPT,6e09a49e-87be-11e8-b421-d43d7e3724e9,0x428,0xdf94760) rawuuid: 6e09a49e-87be-11e8-b421-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 120033558528 offset: 544768 type: freebsd-zfs index: 2 end: 234441607 start: 1064 Consumers: 1. Name: ada0 Mediasize: 120034123776 (112G) Sectorsize: 512 Mode: r1w1e2 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,dba85989-7fa7-11e2-ba31-d43d7e3724e9,0x80,0x400000) rawuuid: dba85989-7fa7-11e2-ba31-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da0p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,dbb4efdb-7fa7-11e2-ba31-d43d7e3724e9,0x400080,0x15d10a308) rawuuid: dbb4efdb-7fa7-11e2-ba31-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da0 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: da1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,dbfdcd6a-7fa7-11e2-ba31-d43d7e3724e9,0x80,0x400000) rawuuid: dbfdcd6a-7fa7-11e2-ba31-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,dc0a50bb-7fa7-11e2-ba31-d43d7e3724e9,0x400080,0x15d10a308) rawuuid: dc0a50bb-7fa7-11e2-ba31-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: da2 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,db534bed-7fa7-11e2-ba31-d43d7e3724e9,0x80,0x400000) rawuuid: db534bed-7fa7-11e2-ba31-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da2p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,db5fbd23-7fa7-11e2-ba31-d43d7e3724e9,0x400080,0x15d10a308) rawuuid: db5fbd23-7fa7-11e2-ba31-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da2 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: da3 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7814037127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,543a65ff-5f13-11ea-beeb-d43d7e3724e9,0x80,0x400000) rawuuid: 543a65ff-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da3p2 Mediasize: 3998639460352 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,544b72c5-5f13-11ea-beeb-d43d7e3724e9,0x400080,0x1d180be08) rawuuid: 544b72c5-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: da3 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: da4 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7814037127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da4p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,536c3218-5f13-11ea-beeb-d43d7e3724e9,0x80,0x400000) rawuuid: 536c3218-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da4p2 Mediasize: 3998639460352 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,537d9fec-5f13-11ea-beeb-d43d7e3724e9,0x400080,0x1d180be08) rawuuid: 537d9fec-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: da4 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: da5 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7814037127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da5p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,550c025b-5f13-11ea-beeb-d43d7e3724e9,0x80,0x400000) rawuuid: 550c025b-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da5p2 Mediasize: 3998639460352 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 efimedia: HD(2,GPT,551dead0-5f13-11ea-beeb-d43d7e3724e9,0x400080,0x1d180be08) rawuuid: 551dead0-5f13-11ea-beeb-d43d7e3724e9 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: da5 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3
gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9.eli OFFLINE 0 0 0 gptid/544b72c5-5f13-11ea-beeb-d43d7e3724e9.eli ONLINE 0 0 0 gptid/551dead0-5f13-11ea-beeb-d43d7e3724e9.eli ONLINE 0 0 0
zpool replace Storage2 gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9.eli gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9geli detach in order to reattach. That reattach worked perfectly and the resilver has started. Thanks very much Patrick, I owe you a beer/beverage of your choice.root@freenas[/mnt/Storage2/iocage/jails/plex/root]# zpool status Storage2
pool: Storage2
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Thu Jan 7 13:04:34 2021
2.52T scanned at 7.76G/s, 69.2G issued at 213M/s, 4.80T total
23.1G resilvered, 1.41% done, 06:27:17 to go
replacing-0 DEGRADED 0 0 0
gptid/537d9fec-5f13-11ea-beeb-d43d7e3724e9 ONLINE 0 0 0 (resilvering)
errors: No known data errorsAwesome thanks. To be sure, this is the case even if they aren't mirrored vdevs right? These expanded the total space in the pool. Sorry just want to be extra sure!Yes, of course. One drive from each RAIDZ2 is still reasonably safe and given there are no other bottlenecks you can speed up the process that way. Don't do two disks from one vdev![]()
Sorry, I don't understand. Redundancy (mirror, RAIDZn) is per vdev. You cannot mirror 2 or more vdevs but the vdev can be a mirror of 2 or more disks. So if (I hope so) you have two vdevs, each a RAIDZ2, then of course you can replace a disk from each vdev and still sleep well, because each vdev keeps one disk redundancy. Lose one vdev, lose the entire pool ...To be sure, this is the case even if they aren't mirrored vdevs right?
