Freenas - to - TrueNas Virtual machine failed to connect to libvirt
HannesM
Hi
The tips Hannes posted worked for a short time, but within about 10 mins I'm getting the "Failed to connect to libvirt" error:
# service middlewared status
middlewared is running as pid 213
# service middlewared restart
Stopping middlewared.
Waiting for PIDS: 213.
Middleware startup is idle for more than 240 seconds
MIDDLEWARED FAILED TO START, SYSTEM WILL NOT BEHAVE CORRECTLY!
middlewared is running as pid 69611
EDIT: restarting the service before rebooting the VM for updates seems to work.
Hi Olly86,
i've the issue a view days ago.... the restart option was not really working in this case. i've used
$ service middlewared stop
wait a view seconds
$ service middlewared start
after this my VMs can restarted. I'm looking forward when the issue is comeing back... knock-knock-knoc 5 day's without broken middleware service.
Regards
Hannes
olly86
Cheers Hannes, that doesn't seem to help mine either I'm needing to do a full system reboot and then restart the service. The VM seems to stay running ok, until it needs a reboot for an update, hopefully a fix is in the works.
fahadshery
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 455, in create
    rv = await self.middleware._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1229, in do_create
    await self.middleware.call('vm.ensure_libvirt_connection')
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1206, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1516, in ensure_libvirt_connection
    raise CallError('Failed to connect to libvirt')
middlewared.service_exception.CallError: [EFAULT] Failed to connect to libvirt
having same issue. TrueNAS-12.0-U1
ChrisRJ
Poor cache invalidation, you mean? No, that's outside my field of expertise. I do know that there have been several attempts over the years to correct this issue, but they never seem to have been fully satisfactory.
The three most underestimated problems in software development:
  • Choosing good names
  • Dependency management
  • Cache invalidation
MGYVR
Dunno if discussion of this has continued in another thread or what, but as of now I am still having this issue on TrueNAS-12.0-U2.1.
Dell R730xt
2x Xeon CPU E5-2680 v3 @ 2.50GHz
64GB RAM
System will run for one to several weeks at a time before middlewared gets wonky, and stops showing correct VM statuses.
The restart command does not really work for me, as the service won't automatically start again after shutting down for some reason.
system middlewared restart
But manually stopping and starting it does the trick.
system middlewared stop
system middlewared start
hescominsoon
Dell R730xt
64GB RAM
I have reported this bug as wlel in jira. I have an r520(noted below) and it happens even with the u2.1 update on here.
olly86
I can't remember which update resolved it, but mine has stopped acting up and is working normally.
