adamzwakk
- Apr 17, 2023
My pool started getting the dreaded
The short test shows that Seek_Error_Rate is 1 thanks to https://yksi.ml/#0x000113323225. Running an extended SMART test on both Ironwolf drives now out of paranoia
Ironically this is happening just after I built a backup machine and replicating data across (reasons for high I/O), but my questions are:
on the same drive a couple times the past few days doing some zfs sends/other intentional possible high I/O on my pool. It's a Seagate Ironwolf (ST8000VN004) so it SHOULDNT be SMR, almost all other drives in there are WD Reds and have no messages. Out of 12, its one of 2 Ironwolf drives in there, and they are the only 7200 RPM drives.Device /dev/gptid/2e598723-7f38-11ed-89d7-6805ca23d2cc is causing slow I/O on pool Vasquez.
- Does this mean I should be replacing the drive in question regadless? I've done most of my homework and figured out the the serial number and everything already, if the extended test shows a 'worse' result then I'll just do it anyways
- Would the difference in RPM produce that kind of result? All other drives are ~5400 RPM, so maybe the drive was complaining about not going at speed during high I/O? (but then I'd assume the other Ironwolf would complain too...)
