NetSoerfer
- May 8, 2016
I upgraded to 11.1 today, and immediately after the upgrade I got critical alerts shown for both SanDisk Extreme 32GB USB Flash Drives I use as boot devices:
Running
Google says that 232 Perc_Avail_Resrvd_Space means that the drive's projected maximum number of erase cycles has been exceeded, but it seems odd:
VALUE = 0, WORST = 100, THRESH = 5 seems like there was an error but there isn't anymore, but the number of erase cycles can't very well have decreased from 100 back to 0, can it?
What do I do with this?
CRITICAL: Dec. 27, 2017, 12:09 p.m. - Device: /dev/da1 [SAT], FAILED SMART self-check. BACK UP DATA NOW! CRITICAL: Dec. 27, 2017, 12:09 p.m. - Device: /dev/da1 [SAT], Failed SMART usage Attribute: 232 Perc_Avail_Resrvd_Space. CRITICAL: Dec. 27, 2017, 12:09 p.m. - Device: /dev/da0 [SAT], FAILED SMART self-check. BACK UP DATA NOW! CRITICAL: Dec. 27, 2017, 12:09 p.m. - Device: /dev/da0 [SAT], Failed SMART usage Attribute: 232 Perc_Avail_Resrvd_Space.
Running
smartctl -a /dev/da0 outputs the following:Code:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: SanDisk based SSDs Device Model: SanDisk pSSD Serial Number: 0074aab31 LU WWN Device Id: 5 001b44 04a0731ab Firmware Version: 6EB 1030 User Capacity: 31,406,948,352 bytes [31.4 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 1.8 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Wed Dec 27 16:49:22 2017 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: FAILED! Drive failure expected in less than 24 hours. SAVE ALL DATA. See vendor-specific Attribute list for failed Attributes. General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x51) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 7) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0002 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0002 100 100 000 Old_age Always - 4 12 Power_Cycle_Count 0x0002 100 100 000 Old_age Always - 0 165 Total_Write/Erase_Count 0x0002 100 100 000 Old_age Always - 2054 171 Program_Fail_Count 0x0002 100 100 000 Old_age Always - 0 172 Erase_Fail_Count 0x0002 100 100 000 Old_age Always - 0 173 Avg_Write/Erase_Count 0x0002 100 100 000 Old_age Always - 0 174 Unexpect_Power_Loss_Ct 0x0002 100 100 000 Old_age Always - 0 187 Reported_Uncorrect 0x0002 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0022 100 000 000 Old_age Always - 0 (0 0 0 192 0) 230 Perc_Write/Erase_Count 0x0002 100 100 000 Old_age Always - 0 232 Perc_Avail_Resrvd_Space 0x0003 000 100 005 Pre-fail Always FAILING_NOW 0 234 Perc_Write/Erase_Ct_BC 0x0002 100 100 000 Old_age Always - 10000 241 Total_LBAs_Written 0x0002 100 100 000 Old_age Always - 0 242 Total_LBAs_Read 0x0002 100 100 000 Old_age Always - 0 SMART Error Log not supported SMART Self-test Log not supported SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
