mka
- Sep 26, 2013
just got an email from FreeNAS saying CRITICAL:
Any ideas what this errors above means and where the problem is?
I'm using the current FreeNAS 9.3
Device: /dev/ada1, Read SMART Error Log Failed
Device: /dev/ada1, failed to read SMART Attribute Data
ada1 is a Intel SSD DC S3500. It was simply forgotten in the scheduled SMART self tests but doesn't show any errors none the less? Or am I missing something?Device: /dev/ada1, failed to read SMART Attribute Data
[root@nas] ~# smartctl -a /dev/ada1 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Intel 730 and DC S3500/S3700 Series SSDs Device Model: INTEL SSDSC2BB120G4 LU WWN Device Id: 5 5cd2e4 04b68ccaa Firmware Version: D2010370 User Capacity: 120,034,123,776 bytes [120 GB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Aug 7 22:26:35 2015 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x02) Offline data collection activity was completed without error. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 2) seconds. Offline data collection capabilities: (0x79) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 2) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 4513 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 6 170 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0 171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0 174 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 3 175 Power_Loss_Cap_Test 0x0033 100 100 010 Pre-fail Always - 633 (26 9264) 183 SATA_Downshift_Count 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 190 Temperature_Case 0x0022 058 057 000 Old_age Always - 42 (Min/Max 28/43) 192 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 3 194 Temperature_Internal 0x0022 100 100 000 Old_age Always - 49 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0 199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0 225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 11561 226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 61 227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 39 228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 270802 232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0 234 Thermal_Throttle 0x0032 100 100 000 Old_age Always - 0/0 241 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 11561 242 Host_Reads_32MiB 0x0032 100 100 000 Old_age Always - 7531 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 4513 - # 2 Extended offline Completed without error 00% 4513 - # 3 Extended offline Completed without error 00% 4513 - # 4 Short offline Completed without error 00% 4513 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
