Critical? failed to read SMART Attribute Data & Error Log
mka
just got an email from FreeNAS saying CRITICAL:
Device: /dev/ada1, Read SMART Error Log Failed
Device: /dev/ada1, failed to read SMART Attribute Data
ada1 is a Intel SSD DC S3500. It was simply forgotten in the scheduled SMART self tests but doesn't show any errors none the less? Or am I missing something?
Any ideas what this errors above means and where the problem is?
[root@nas] ~# smartctl -a /dev/ada1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build)
Model Family:     Intel 730 and DC S3500/S3700 Series SSDs
Device Model:     INTEL SSDSC2BB120G4
LU WWN Device Id: 5 5cd2e4 04b68ccaa
Firmware Version: D2010370
User Capacity:    120,034,123,776 bytes [120 GB]
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Aug  7 22:26:35 2015 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x02) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (    2) seconds.
capabilities:                    (0x79) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
Conveyance self-test routine
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       4513
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       6
170 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
174 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       3
175 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       633 (26 9264)
183 SATA_Downshift_Count    0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   090    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
190 Temperature_Case        0x0022   058   057   000    Old_age   Always       -       42 (Min/Max 28/43)
192 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       3
194 Temperature_Internal    0x0022   100   100   000    Old_age   Always       -       49
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
225 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       11561
226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       61
227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       39
228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       270802
232 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       0
234 Thermal_Throttle        0x0032   100   100   000    Old_age   Always       -       0/0
241 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       11561
242 Host_Reads_32MiB        0x0032   100   100   000    Old_age   Always       -       7531
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      4513         -
# 2  Extended offline    Completed without error       00%      4513         -
# 3  Extended offline    Completed without error       00%      4513         -
# 4  Short offline       Completed without error       00%      4513         -
I'm using the current FreeNAS 9.3
mka
Ok. Last night multiple more errors occurred on device ada0, ada1, ada2.
This was not important data but SSDs for small server processes which could easily be replaced from backups. tank0 was not affected apart from his L2ARC drive.
Device: /dev/ada1, unable to open device
The volume tank1 (ZFS) state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
The volume tank0 (ZFS) state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state.
Device: /dev/ada0, unable to open device
Device: /dev/ada2, unable to open device
The volume tank1 (ZFS) state is UNAVAIL: One or more devices are faulted in response to IO failures.
This makes me think it is the SATA controller. ada0, ada1, ada2 reside on the same external controller (Marvell 88SE9230).
And I also got mail from freenas saying:
ahcich1: Timeout on slot 27 port 0
ahcich1: is 00000000 cs 08000000 ss 00000000 rs 08000000 tfd 50 serr 00000000 cmd 10009b17
ahcich1: Timeout on slot 22 port 0
ahcich1: is 00000000 cs 00400000 ss 00000000 rs 00400000 tfd 50 serr 00000000 cmd 10009617
when looking at /var/run/dmesg.boot
ahci0: <Marvell 88SE9230 AHCI SATA controller> port 0x4050-0x4057,0x4040-0x4043,0x4030-0x4037,0x4020-0x4023,0x4000-0x401f mem 0xc1310000-0xc13107ff irq 17 at device 0.0 on pci2
ahci0: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci0: quirks=0x900<NOBSYRES,ALTSIG>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
EDIT:
After shutting down the system and rebooting it, the drives and controller were up and running and working without problem. A scrub on tank1 didn't reveal any data corruption but I don't trust that controller very much anymore.
SweetAndLow
Sweet'NASty
This is what happens with marvel controllers and this is why most people suggest not using them. They are not very good and will cause issues.
DrKK
FreeNAS Generalissimo
Definitely Marvell controller.
mka
Ok. I'm already working on replacement
Thanks
