SOLVED Crucial MX300 SSD SMART failure
Klontje
Hello all,
I can't find any official documentation around this and want to check here. I have a mirrored pool consisting of two Crucial MX300's which FreeNAS both reports as failing. This is based on the SMART value 202 Percent_Lifetime_Used. I have a feeling however this value is interpreted in a wrong way but the only thing Crucial can tell me is that I need to install their Windows software...
If you look at the report below, you can see that the VALUE reports a 1 as current and maximum value. The RAW value is reported as 99. My gut tells me that the numbers are reported the wrong way around as both SSD's are less than a year old.
Can anyone confirm that the report below without any doubt tells that the lifetime used is 99% and not 1%?
Model Family:	 Crucial/Micron MX1/2/300, M5/600, 1100 Client SSDs
Device Model:	 Crucial_CT525MX300SSD1
Serial Number:	170815XXXXXX
LU WWN Device Id: 5 00a075 115fee734
Firmware Version: M0CR040
User Capacity:	525,112,713,216 bytes [525 GB]
Sector Size:	  512 bytes logical/physical
Rotation Rate:	Solid State Device
Form Factor:	  2.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Thu Jan 18 16:20:12 2018 CET
SMART support is: Enabled
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
No failed Attributes found.
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (  64) The previous self-test completed having
										a test element that failed and the test
										element that failed is not known.
data collection:				( 1169) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		(   6) minutes.
Conveyance self-test routine
recommended polling time:		(   3) minutes.
SCT capabilities:			  (0x0035) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   100   100   000	Pre-fail  Always	   -	   0
  5 Reallocate_NAND_Blk_Cnt 0x0032   100   100   010	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   5881
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   32
171 Program_Fail_Count	  0x0032   100   100   000	Old_age   Always	   -	   0
172 Erase_Fail_Count		0x0032   100   100   000	Old_age   Always	   -	   0
173 Ave_Block-Erase_Count   0x0032   001   001   000	Old_age   Always	   -	   1485
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000	Old_age   Always	   -	   29
183 SATA_Interfac_Downshift 0x0032   100   100   000	Old_age   Always	   -	   0
184 Error_Correction_Count  0x0032   100   100   000	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
194 Temperature_Celsius	 0x0022   066   056   000	Old_age   Always	   -	   34 (Min/Max 20/44)
196 Reallocated_Event_Count 0x0032   100   100   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   100   100   000	Old_age   Always	   -	   0
202 Percent_Lifetime_Used   0x0030   001   001   001	Old_age   Offline  FAILING_NOW 99
206 Write_Error_Rate		0x000e   100   100   000	Old_age   Always	   -	   0
246 Total_Host_Sector_Write 0x0032   100   100   000	Old_age   Always	   -	   809048933325
247 Host_Program_Page_Count 0x0032   100   100   000	Old_age   Always	   -	   25282779626
248 Bckgnd_Program_Page_Cnt 0x0032   100   100   000	Old_age   Always	   -	   2276693842
180 Unused_Reserve_NAND_Blk 0x0033   000   000   000	Pre-fail  Always	   -	   1943
210 Success_RAIN_Recov_Cnt  0x0032   100   100   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Self-test routine in progress 90%	  5880		 -
# 2  Short offline	   Completed without error	   00%	  5856		 -
# 3  Short offline	   Completed without error	   00%	  5832		 -
# 4  Extended offline	Completed without error	   00%	  5819		 -
# 5  Short offline	   Completed without error	   00%	  5808		 -
# 6  Conveyance offline  Completed without error	   00%	  5793		 -
# 7  Short offline	   Completed without error	   00%	  5784		 -
# 8  Short offline	   Completed without error	   00%	  5760		 -
# 9  Short offline	   Completed without error	   00%	  5736		 -
#10  Short offline	   Completed without error	   00%	  5712		 -
#11  Short offline	   Completed without error	   00%	  5688		 -
#12  Short offline	   Completed without error	   00%	  5664		 -
#13  Extended offline	Completed without error	   00%	  5651		 -
#14  Short offline	   Completed without error	   00%	  5640		 -
#15  Conveyance offline  Completed without error	   00%	  5625		 -
#16  Short offline	   Completed without error	   00%	  5617		 -
#17  Short offline	   Completed without error	   00%	  5592		 -
#18  Short offline	   Completed without error	   00%	  5567		 -
#19  Short offline	   Completed without error	   00%	  5543		 -
#20  Short offline	   Completed without error	   00%	  5519		 -
#21  Short offline	   Completed without error	   00%	  5495		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SweetAndLow
Sweet'NASty
Everything looks accurate and would be reported exactly the same on windows. All your smart tests are passing also. Nothing indicates the drive is failing. The only thing you need to care about is if the smart tests pass or fail. You can ignore all the numbers.
Klontje
Hey SweetAndLow, the following lines indicate an error and FreeNAS GUI is also reporting imminent danger...
SweetAndLow
Sweet'NASty
What does the gui say? Screenshot?
Klontje
The same SMART variable as mentioned above, see image below
SweetAndLow
Sweet'NASty
Well I would say those drives are failing. Strange failure since smart tests are still passing. Time to rma those disks.
Klontje
My thought, but if you look at the mentioned SMART attribute I get the feeling the values are wrongly interpreted (in reverse) as the VALUE has never been higher than one what would indicate it is going up instead of down. Based on that I would assume RAW_VALUE is going down. Hence my question.
SweetAndLow
Sweet'NASty
I don't know. The drive does it all and has nothing to do with FreeNAS. The drive says it's failing.
Klontje
I ordered a new one, will replace one and analyze the old disk with the Crucial software on a Windows machine and report back.
Most likely, it's just reporting data in a format that smartctl misunderstands. Happens all the time with SSDs.
Klontje
That's what I'm afraid of, I already requested an RMA with Amazon and they are very pro-active, just got an e-mail a new one is already on the way...
Question is, how do I get rid of the red flashing light in my console?
FreeNAS isn't misinterpreting the SMART data, the SSD has a failing_now attribute:
The Value is 100 on a new SSD and the RAW value is 0, as the value decreases with usage the RAW value increases, when it reaches the threshold that SMART attribute changes to FAILING_NOW.
Now, with this type of attribute it doesn't mean the SSD is failing, but for comparison here's the same SMART attribute from a newer CX300:
202 Percent_Lifetime_Used   0x0031   098   098   000	Pre-fail  Offline	  -	   2
Still 98% estimated life left.
Edit: the above is from an MX100, they are similar but the Threshold is 1 instead of 0 for the MX300
You can't be sure without checking with the manufacturer's tool. SSD vendors play fast and loose with SMART.
You can, it will report the same, the FAILING_NOW attribute is being reported by the SSD, it's not being interpreted.
MrToddsFriends
Documentation Browser
The latest FreeNAS release (11.1-U1, released a few hours ago) has a more recent version of smartmontools included (6.6 instead of 6.5). If you are brave enough or if you were already ready to make the jump to FreeNAS 11.1-xx, you could try that version and report back to us.
P.S. If my calculations are correct that SSD has written ~414TB, well over the 160TB endurance quoted by Crucial, so it's been at 99%+ for a while.
Also won't make any difference, that SSD is already known by v6.5, I even forgot I recently installed some MX500s on my server, these are still unknown by smartmontools 6.5, but that only means some attributes are unknown, it would still report a FAILING_NOW attribute (when the normalized value reaches the Threshold value).
Practically new MX500 on FreeNAS 11.0U4, life remaining is attribute 202:
smartctl -a /dev/ada9
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:	 CT250MX500SSD1
Serial Number:	1749E107ACC4
LU WWN Device Id: 5 00a075 1e107acc4
Firmware Version: M3CR010
User Capacity:	250,059,350,016 bytes [250 GB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Device is:		Not in smartctl database [for details use: -P showall]
SATA Version is:  SATA >3.2 (0x1ff), 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Thu Jan 18 22:24:56 2018 WET
Offline data collection status:  (0x80) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(	0) seconds.
										command.
										power-saving mode.
recommended polling time:		(  30) minutes.
SCT capabilities:			  (0x0031) SCT Status supported.
  5 Reallocated_Sector_Ct   0x0032   100   100   010	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   62
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   1
171 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   0
172 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   0
173 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   3
174 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033   000   000   000	Pre-fail  Always	   -	   24
183 Runtime_Bad_Block	   0x0032   100   100   000	Old_age   Always	   -	   0
184 End-to-End_Error		0x0032   100   100   000	Old_age   Always	   -	   0
194 Temperature_Celsius	 0x0022   067   058   000	Old_age   Always	   -	   33 (Min/Max 0/42)
202 Unknown_SSD_Attribute   0x0030   100   100   001	Old_age   Offline	  -	   0
206 Unknown_SSD_Attribute   0x000e   100   100   000	Old_age   Always	   -	   0
210 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   0
246 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   367834372
247 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   6165790
248 Unknown_Attribute	   0x0032   100   100   000	Old_age   Always	   -	   13290949
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Completed [00% left] (0-65535)
Klontje
Hey Johnie, thanks for your reply, I'll double check with the Crucial tools, two new drives (one bought and one RMA) are on their way to me today.
The errors popped-up yesterday for the first time. I'm ususally pretty pro-active with replacing disks.
They might not replace it since it didn't fail, an Old_age attribute failing_now just means it's past the design life, total TBW in this case, unless there's other issues or failing SMART tests it can still last for long time without any problems, in fact manufacturers won't usually replace it if still under warranty and there are real problems but it's past the rated TBW.
If you get the chance to check it with the Crucial software please post the total TB written, most curious about that.
Klontje
I've been looking into the warranty terms posted online (http://eu.crucial.com/eur/en/company-warranty). Warranty is limited to 3 years or the TBW mark. This means that I written that in less than a year and basically can throw away the SSD which I think is quite fast. I am running jails on them and wondering how else should I do this, I don't want to buy new SSD's every 10 months...
