faxfan2002
- Apr 24, 2020
Hi All,
I've got 4 new drives and new to free NAS, one of the drives has coming as failing. The drives are not in the in database and the smartctl for the failing drive is -
root@freenas[~]# smartctl -a /dev/da2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: TOSHIBA HDWG11A
Serial Number: 2030A0JYFATG
LU WWN Device Id: 5 000039 9f8c8b8d0
Firmware Version: 0603
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Apr 25 17:03:56 2020 BST
SMART support is: Enabled
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1011) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 9389
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 20
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 028 028 050 Pre-fail Always FAILING_NOW 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 39
10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 21
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 35 (Min/Max 19/46)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 202113064
222 Loaded_Hours 0x0032 100 100 000 Old_age Always - 39
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 530
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Interestingly the other 3 drives are all showing "pre-fail" statuses -
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 9112
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 33 (Min/Max 22/44)
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 219152397
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 538
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 9453
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 34 (Min/Max 22/47)
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 68550661
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 528
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 9270
7 Seek_Error_Rate 0x000b 100 099 050 Pre-fail Always - 0
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 34 (Min/Max 20/47)
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 184811531
No Errors Logged
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
No Errors Logged
