Sith Empire
- Jun 18, 2018
Hi everyone. I have a very basic FreeNAS setup ( (1) 128GB SSD boot/FreeNAS disk and (2) 2TB Segate drives for jails, media storage, etc.); Unfortunately the 2 TB drives are in a striped configuration and one has started taking on errors:
Output from smartctl -a /dev/ada2:
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST2000DM001-1CH164
Serial Number: Z340V559
LU WWN Device Id: 5 000c50 066248858
Firmware Version: CC29
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Jun 18 00:32:46 2018 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 584) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 225) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 225269928
3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 199
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 080 060 030 Pre-fail Always - 101047145
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 20528
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 563
183 Runtime_Bad_Block 0x0032 095 095 000 Old_age Always - 5
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 083 000 Old_age Always - 27 29 49
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 060 046 045 Old_age Always - 40 (Min/Max 29/43)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 224
193 Load_Cycle_Count 0x0032 076 076 000 Old_age Always - 48639
194 Temperature_Celsius 0x0022 040 054 000 Old_age Always - 40 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 16
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 16
199 UDMA_CRC_Error_Count 0x003e 200 196 000 Old_age Always - 845
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 18121h+28m+36.702s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 25189095044
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 13052532725
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Aborted by host 20% 2070 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@nas1:~ #
Can I add a new 2TB disk and use the 'replace' feature to resilver the data from the failing drive to the new drive, then remove the failing drive once that is complete? If the answer is no, then would someone be kind enough to explain how I go about:
1. backing up all of my data
2. Adding two additional 2TB drives (for a total of 3 drives) and setting up RAIDZ1
3. Restoring my data to the new RAIDZ1 pool
I realize that this is probably a very tall order, but I really could use a hand with all of this.
Thanks in advance,
Mac
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@nas1:~ #
Thanks in advance,
Mac
