My Setup (it's old):
Motherboard is ASUS M4A78LT-M
CPU is AMD Athalon II X2 250
RAM is 8GB
HDs: Seagate 1TB ST1000DM003-1ER162
Freenas 9.10.2-U4 (27ae72978)
I am getting errors on /dev/ada3. When I look into my Volume Status, it looks like there are no issues on /dev/ada3p2. I guess my first question is how do I find out what /dev/ada3 is? From the Volume Status it appears my data is on /dev/ada3p2 (does this mean Partition 2?). Below is the output of SMARTCTL. I could run it on /dev/ada3 but not /dev/ada3p2. I need some guidance on where to start to troubleshoot...
RAM is 8GB
smartctl -a /dev/ada3Code:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.14 (AF) Device Model: ST1000DM003-1ER162 Serial Number: Z4YBKW5N LU WWN Device Id: 5 000c50 087b68c15 Firmware Version: CC46 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Mon Jun 26 00:08:55 2017 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 80) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 105) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x1085) SCT Status supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 140339832 3 Spin_Up_Time 0x0003 098 097 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 20 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 078 060 030 Pre-fail Always - 60000073 9 Power_On_Hours 0x0032 088 088 000 Old_age Always - 11066 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 20 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 059 044 045 Old_age Always In_the_past 41 (Min/Max 30/47 #19) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 9 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 68 194 Temperature_Celsius 0x0022 041 056 000 Old_age Always - 41 (0 9 0 0 0) 197 Current_Pending_Sector 0x0012 094 093 000 Old_age Always - 1008 198 Offline_Uncorrectable 0x0010 094 093 000 Old_age Offline - 1008 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 11066h+38m+55.002s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 10519176548 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 37509088737 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 10949 - # 2 Short offline Completed without error 00% 10686 - # 3 Extended offline Completed without error 00% 10613 - # 4 Extended offline Completed without error 00% 10205 - # 5 Short offline Completed without error 00% 10182 - # 6 Extended offline Completed without error 00% 9940 - # 7 Extended offline Interrupted (host reset) 10% 9932 - # 8 Short offline Completed without error 00% 9931 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
