scrool
- Apr 30, 2022
On TrueNAS-SCALE-22.02.3 I have installed official InfluxDB container image in version 1.8.x (1.8.10). I have enabled Graphite plugin (
I would like to simplify queries with templates. I have enabled "Graphite Separate Instances" in a hope that it would match measurements easier. I have following measurements now:
I have found great resources how to configure InfluxDB https://www.truenas.com/community/threads/guide-to-setting-up-grafana-influxdb-metrics.88943/ , https://github.com/cucac/truenas-influxdb-grafana or other posts like https://www.truenas.com/community/t...cpu-disk-and-other-metrics.87107/#post-604023 that seem to work for cases where InfluxDB's configuration file can be edited directly.
In my case it would be config snippet like:
Since this is a container I need to set this value from environment variable. Container apparently accepts
and with that I ended up with just
But to add second template, which would be written in the config like this:
and my measurements matching these:
I have tried to quote values:
but that failed to start the server with error in logs:
or:
(and other combination of DOS newlines) failed with:
Could anybody help me with a way to represent this?
INFLUXDB_GRAPHITE_ENABLED=true
). In TrueNAS I changed reporting to this server.I would like to simplify queries with templates. I have enabled "Graphite Separate Instances" in a hope that it would match measurements easier. I have following measurements now:
SHOW MEASUREMENTS WITH MEASUREMENT =~ /disktemp.*.temperature*/' name: measurements name ---- servers.my_server.disktemp.sda.temperature servers.my_server.disktemp.sdb.temperature servers.my_server.disktemp.sdc.temperature servers.my_server.disktemp.sdd.temperature servers.my_server.disktemp.sde.temperature servers.my_server.disktemp.sdf.temperature servers.my_server.disktemp.sdg.temperature servers.my_server.disktemp.sdh.temperature
templates = [ "*.*.disktemp.*" ".host.measurement.disk.field" ]
INFLUXDB_GRAPHITE_TEMPLATES
. I was able to set one template entry, e.g.Code:
*.*.disktemp.* .host.measurement.disk.field
disktemp
measurements.But to add second template, which would be written in the config like this:
templates = [ "*.*.disktemp.*" ".host.measurement.disk.field" "*.*.cputemp.*" ".host.measurement.cpu.field" ]
SHOW MEASUREMENTS WITH MEASUREMENT =~ /cputemp.*/' name: measurements name ---- servers.my_server.cputemp.0.temperature servers.my_server.cputemp.1.temperature servers.my_server.cputemp.2.temperature servers.my_server.cputemp.3.temperature
"*.*.disktemp.* .host.measurement.disk.field" "*.*.cputemp.* .host.measurement.cpu.field"
run: invalid graphite config: invalid template format: '"*.*.disktemp.* .host.measurement.disk.field" "*.*.cputemp.* .host.measurement.cpu.field"'. To generate a valid configuration file run `influxd config > influxdb.generated.conf`
or:
*.*.disktemp.* .host.measurement.disk.field\n*.*.cputemp.* .host.measurement.cpu.field
run: invalid graphite config: invalid template tags: '.host.measurement.cpu.field'. To generate a valid configuration file run `influxd config > influxdb.generated.conf`
