BACKUP NAS build with AlderLake (i5-12600)
Etorix
Safe choice… and, I guess, already some savings over the initial Alder Lake plan. More RAM is always better, but 16 GB should do for a backup system. If the plan is still 5 * 4 TB, don't bother with a hot spare, just go for 5 drives in raidz2, this will be safer than 4 in raidz1 + 1 spare.
PtitLu
Hi guys , I just set up my build , now trueNAS is installed and i just get in the WebUser interface . I have already a notification about SMART like this :
CRITICAL
Device: /dev/ada1, Failed SMART usage Attribute: 183 Unknown_Phison_Attr.. ,
is it a common thing ? this disk is brand new WD 6TB RED PLUS disk
Thanks
Etorix
Never seen that… and obviously TrueNAS hasn't seen it either. It is probably safe to ignore, but you can post here the output of smartctl -a /dev/ada1 within [ CODE ] tags (</> from … at the far right of the format bar) for us to inspect.
PtitLu
Hi , here it is : This is 1 HDD brand new and old SSD where truenas is installed temporary.
Model Family: Phison Driven SSDs
Device Model: KINGSTON SHSS37A240G
Firmware Version: SAFM00.r
User Capacity: 240,057,409,536 bytes [240 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Mar 28 05:35:20 2022 PDT
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
was never started.
been run.
data collection: ( 30) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Not_In_Use 0x0005 100 100 050 Pre-fail Offline - 0
3 Not_In_Use 0x0007 100 100 050 Pre-fail Always - 0
5 Retired_Block_Count 0x0013 100 100 050 Pre-fail Always - 0
7 Not_In_Use 0x000b 100 100 050 Pre-fail Always - 0
8 Not_In_Use 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 15798
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 3152
168 SATA_Phy_Error_Count 0x0012 100 100 000 Old_age Always - 31
170 Bad_Blk_Ct_Erl/Lat 0x0003 100 100 010 Pre-fail Always - 0/675
173 MaxAvgErase_Ct 0x0012 100 100 000 Old_age Always - 293 (Average 217)
175 Not_In_Use 0x0013 100 100 050 Pre-fail Always - 0
183 Unknown_Phison_Attr 0x0012 100 100 100 Old_age Always FAILING_NOW 19202265
187 Reported_Uncorrect 0x0012 100 100 000 Old_age Always - 0
192 Unsafe_Shutdown_Count 0x0012 100 100 000 Old_age Always - 186
194 Temperature_Celsius 0x0023 076 059 030 Pre-fail Always - 24 (Min/Max 13/41)
196 Reallocated_Event_Count 0x0002 100 100 010 Old_age Always - 0
197 Not_In_Use 0x0032 100 100 000 Old_age Always - 0
199 SATA_CRC_Error_Count 0x000b 100 100 050 Pre-fail Always - 11
218 CRC_Error_Count 0x000b 100 100 050 Pre-fail Always - 11
231 SSD_Life_Left 0x0013 100 100 000 Pre-fail Always - 93
233 Flash_Writes_GiB 0x000b 100 100 000 Pre-fail Always - 44860
240 Not_In_Use 0x0013 100 100 000 Pre-fail Always - 0
241 Lifetime_Writes_GiB 0x0012 100 100 000 Old_age Always - 26875
242 Lifetime_Reads_GiB 0x0012 100 100 000 Old_age Always - 31429
244 Average_Erase_Count 0x0002 100 100 000 Old_age Always - 217
245 Max_Erase_Count 0x0002 100 100 000 Old_age Always - 293
246 Total_Erase_Count 0x0012 100 100 000 Old_age Always - 14811776
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@truenas[~]#
root@truenas[~]# smartctl -a /dev/ada0
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p12 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD60EFZX-68B3FN0
LU WWN Device Id: 5 0014ee 26a306945
Firmware Version: 81.00A81
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5640 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
Local Time is: Mon Mar 28 05:36:41 2022 PDT
was never started.
been run.
data collection: (64320) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
No Selective Self-test supported.
power-saving mode.
recommended polling time: ( 680) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 201 194 021 Pre-fail Always - 6916
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 13
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 5
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 13
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 7
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 8
194 Temperature_Celsius 0x0022 129 123 000 Old_age Always - 23
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 253 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
Etorix
OK… So the unknown attribute comes from a SSD but showed up as if it were associated to the HDD at ada1.
There's a known issue with matching reports/information with devices and your issue is a variation on that, possibly aggravated here because it has confused a SSD for a HDD.
I think there already is a JIRA ticket for this abnormal behaviour from TrueNAS, but I can't find the thread and ticket.
