Lipsum Ipsum
- Aug 31, 2022
I posted my pending build in my sig. It's actually kind of funny how similar our builds are as well as use-case. The significant hardware was easy to decide on. I can't believe the amount of time I went around and around trying to decide on a case. Definitely paralysis by analysis.Also if you got the time, would you be able to share your PC/Server build? it would be very interesting to know what route you went in terms of CPU, CPU Cooler, HDD/SSD & PC Case choice :)
I really was hoping I could find something that looked closer to a Synology or QNAP with desktop/shelf sexiness, but had more DIY flexibility and could fit a ATX mobo. The NAS 8-bay K7 case was the closest I could find but looks like it was made in the 1980s. It claims it fits an ATX board, but I think that's a typo as the stated dimensions are only 9.6" square.
I finally just decided to go with the Fractal Design Define 7, but then I had to decide on the just the Define 7 or the Define 7 XL with solid side panels. Back and forth, was it going to sit on the floor or the desk behind one of my monitors? Oh look, the Phanteks Enthoo Evolv X also has a little spot for a mini-ITX I could add my desktop in the same case and free up some more room. Well screw that, lets go big or go home with the Thermaltake Core W200! Damnit why can't they make the Define 7 Nano hold 14 drives too!??1!one? Finally settled on the Define 7 (no XL) balancing cost, size, and drive capacity.
I'm holding off on the main pool drives to see what Black Friday/Cyber Monday might bring if anything. I may also press my luck with some alleged "manufacturer refurbished" drives from ServerPartsDeals. I have an existing non-NAS media server using Drive Pool that the new one will replace that's not quite full, so I'm not in a super big hurry.
I'm also not 100% committed to ultimately going with TrueNAS at the moment. Saying that isn't ban-worthy here is it? :) I'm MUCH more comfortable with Windows Server, Hyper-V, and the .Net world as a developer, so jumping ship to TrueNAS is a major overall change for me. I'm no stranger to the Linux and Unix world either though so that helps.
