Another pool degraded question.
bar1
Hi everyone,
Sorry I am sure it was asked many time but I can't find the answer.
I have a degraded pool, and I suspect this is the reason:
<0x9572>:<0x927>
/Bar1-xxx/xxx/xxx/xx/vm-123-disk-0.raw
This file can be deleted however I can only mount my pool as read only....
How do I go about deleting this file and getting my pool up and running again?
bar1
By the way first prize will be to try and repair this file, but I do have a backup
bar1
Is this safe to do?
Arwen
You really need to learn both ZFS and TrueNAS, (based on your questions).
Please follow the forum rules, (up at the top of any forum page, in bold red). And the output of zpool status as loss of a file indicates that you probably have pool problems.
Arwen
What I meant was that the forum rules request hardware configuration, version of TrueNAS and a description of your ZFS pool put in your post. (Or follow on post.)
I also suggested the output of the command zpool status but was not clear that you should put it in a post so we can look at it.
As for the reading, their are a TON of Resources, (and some sticky forum threads). Some forum members keep the suggested newer user ones in their signature. But, I have not yet done that, so I have to look them up. Here are some of the ones I mean;
To answer your question, "Is this safe to do?", depends on what you want to accomplish. Let's stick to the pool corruption first.
bar1
I would like to get my pool up and running,
I am running truenas scale, without raid, I am willing to lose the corrupt file but prefer not to.
I do not want to loose the whole ZFS volume / the datasets on this hard drive, but to repair it and get it online.
I thought it was obvious....apologizes, let me clarify.
Is it safe to add the unassigned disk to the new pool?
Meaning safe as no data will be erased from the disk.
By the way, I can mount the disk just fine as read only.
root@truenas[/]# zpool status
pool: Bar1-8TB
state: ONLINE
scan: scrub repaired 0B in 17:32:29 with 0 errors on Sun Dec 18 17:32:46 2022
NAME STATE READ WRITE CKSUM
Bar1-8TB ONLINE 0 0 0
b43e1073-1684-4339-bce3-302c3d9e2e8c ONLINE 0 0 0
errors: No known data errors
pool: Bar1-APPS
state: ONLINE
scan: scrub repaired 0B in 00:01:51 with 0 errors on Sun Dec 11 00:02:02 2022
Bar1-APPS ONLINE 0 0 0
6e39535a-010b-46e8-a9b9-c847a829251e ONLINE 0 0 0
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:01:23 with 0 errors on Tue Jan 3 03:46:25 2023
boot-pool ONLINE 0 0 0
sdc3 ONLINE 0 0 0
root@truenas[/]#
Currently not even showing the corrupted pool.
If I mount as readonly:
oot@truenas[/3]# zpool status -v
pool: Bar1-18TB
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub in progress since Sun Dec 18 00:00:09 2022
4.40T scanned at 0B/s, 4.40T issued at 0B/s, 7.96T total
0B repaired, 55.34% done, no estimated completion time
Bar1-18TB DEGRADED 0 0 0
d9d82275-2a5f-4c78-a81e-499766926f4a DEGRADED 0 0 0 too many errors
<0x9572>:<0x927>
/xxxxvm-123-disk-0.raw
pool: Bar1-8TB
state: ONLINE
pool: Bar1-APPS
state: ONLINE
pool: boot-pool
state: ONLINE
sdc3 ONLINE 0 0 0
bar1
I am very scared to do something wrong and loose my whole drive,
I read some of the documentation, and been using ZFS for years now, but never had an issue.
I will apriciate an advice here please.
Etorix
<0x9572>:<0x927>
The latter is a real file, and could be deleted or restored individually from backup.
The former is ZFS internal metadata and cannot be repaired.
Copy everything which has changed since the last backup, destroy the pool and restore the whole lot from backup.
Davvo
Please put the output of any code you run within the appropriate BBCode as per forum rules.
As well as please list your full hardware specs as per forum rules.
You also don't look like someone who understands what ZFS is and how it works so please read the resources you were liked to.
That file can't be recovered anymore.
bar1
SYSTEM:
TrueNAS-SCALE-22.12.0
PROXMOX VM - 16GB RAM
4 Cores
18tb Hard disk passthrough
8GB Hard disk passthrough
I see some advise to delete the file, and run scrub, but I am struggling to mount the file system not in read only
Davvo
I hate being a nitpicker.
Correct me if I'm wrong: you are running TrueNAS as a VM in proxmox with 16GB of non-ECC RAM, and you are using single drives with no redundancy for your pools.
Whattteva
This.... looks ugly.
If you're going to virtualize, you need to passthrough the entire controller, not just the hard disks.
bar1
I was struggling with the controller passthrough...did a bit of research and people said hard drive passthrough is fine :-(
I guess not.
That is correct @Davvo and I promise once i sort out my ZFS I will set up my system properly as a spolier (tried to figure it out, I understand it probably super easy but I am stressing about my pool at the moment).
I do have a backup just trying to avoid a long restore.
bar1
Setup: important data on the 18TB get replicated to the 8TB
and all the data get synced to encryped google drive (however didn't get it right just yet)
Davvo
You can try zpool import -f Bar1-18TB.
Hard drive passthrough is fine if the drives are directly attached to the motherboard iirc.
Whattteva
Well, it looks like at least you did something right (backups). Plenty of people come here weeping losing tens of TB of precious data on botched sub-optimal setups. Why anyone would do that on data they care about is beyond me.
More on-topic, I'm guessing some of your meta-data got bungled because you're not quite passing through the actual controller.
You still haven't really given us your HW specs. What you instead gave us is your VM specs... which is obviously not the same thing.
My guess that you had problem passing through your controller is due to the CPU not having VT-d support.
bar1
didn't work...
Ok....external hard drive is connected, let me start a copy while in read only.
I am also not too sure what to do after....do I just wipe the drive and start over?
Davvo
didn't work...
Try zpool import -F Bar1-18TB.
Although I would just nuke everything and start from scratch with a proper system.
