SneekyMellon
- Nov 10, 2022
Hi Everyone,
I recently built a TrueNas system and got a bad drive after about a month or two of perfect operation. No worries, bought a new one and slapped her in. The pool did its thing and all the data is where it should be (as far as I can tell).
The issue is now Two of my drives are showing as degraded as there are six bad files that I assume are log files judging by the file path.
My question is: how do I get this pool health again. as far as I can tell its working normally despite this and has been for about a month or so. What are these files? can I just delete them?
Any help much appreciated.
root@Kuiper[~]# zpool status -v pool: Main state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub repaired 0B in 08:04:55 with 7 errors on Sun Nov 6 08:04:55 2022 config: NAME STATE READ WRITE CKSUM Main DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 gptid/99ad3e1b-f687-11ec-9863-94de806c01b7 ONLINE 0 0 0 gptid/99bda67a-f687-11ec-9863-94de806c01b7 DEGRADED 0 0 0 too many errors gptid/9aa57963-f687-11ec-9863-94de806c01b7 DEGRADED 0 0 0 too many errors gptid/c87c9618-2f40-11ed-8f14-94de806c01b7 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: /var/db/system/syslog-481d11dc8be44177a340c08096234a34/log/messages /var/db/system/syslog-481d11dc8be44177a340c08096234a34/log/console.log /var/db/system/syslog-481d11dc8be44177a340c08096234a34/log/daemon.log /var/db/system/syslog-481d11dc8be44177a340c08096234a34/log/middlewared.log /var/db/system/syslog-481d11dc8be44177a340c08096234a34/log/samba4/log.smbd /var/db/system/syslog-481d11dc8be44177a340c08096234a34/log/samba4/log.nmbd pool: boot-pool state: ONLINE status: Some supported and requested features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0B in 00:00:05 with 0 errors on Wed Nov 2 03:45:05 2022 config:
