I'm building my NAS in a Fractal Design Node 804 which can apparently fit 10 3.5 Drives. So I was going to use 5x4TB drives on RAIDZ2 to start off and be able to expand later since I know ZFS doesn't allow expansion right now. But would there be any issues not using an even number of drives? I was thinking I should probably go for 6, but that would basically make expansion impossible later. I've been searching for a while and I've seen mixed responses, so I just want to make sure. Btw, I know this probably doesn't have anything to do with this, but since the server motherboard has only 4 SATAs and 1 M.2 and I will be using a LSI 9207-8i PCIE3.0 6Gbps HBA for the other drives.
