ultimateon
- Oct 22, 2014
So after 3 years of running FreeNAS on this machine with the current setup I have finally started running into massive amounts of problems.
First off let me post the builds to my FrankenNAS
Original
HP Microserver N54L
4 Gigs of ECC ram
1x1 TB WD Green(Pre Intellipark)
1x2 TB WD Green (Intellipark Enabled)
1x3 TB WD Green (Intellipark Enabled)
Kingstone dataTraveler 16 GB(Boot Drive)
Current
HP Microserver N54L
8 Gigs of non ECC ram (Gskill 1600 MHz ripjaws Z) (need to find another Cheap compatible stick of 4 gigs of ECC ram DAMM the cursed economy now with the price of the dólar skyrocketing everything is expensive!)
1x1 TB WD Green(Pre Intellipark) (Still working)
1x2 TB WD Green (Intellipark Disabled) (Died last month ago along with the dataset and 320 GB of somone else's life I said I might lose!)
1x3 TB WD Green (Intellipark Enabled)(Died before disabling intellipark)
1x4 TB WD Red
1x1 TB Seagate Samsung 2.5 pulled of a Portable Hard drive adaptor (Soon to be replaced by a Toshiba Store-E HDD which has yet to been identified)(Sectors dead ATM 46 and increasing)
1x 320 GB Seagate Samsung Drive( Working as a cache drive)
So I powered the system off Last night because I had to do some cleaning around it and in the morning after a VERY slow boot I get this warning
"The volume home (ZFS) state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected."
So I need to know If this is either a Hard drive failiure (forcing me to move away from FreeNAS for a time until I can aquire 2 more 4 TB reds and a cheap SSD (Damm this economy) ). Or is it a RAM error (Which I will test them further along this afternoon with memtest after removi- no wait I just made this dataset a week ago besides a few movies i'm not losing anything important).
I'm uploading the Debug Logs anything else let me know I'm watching this thread, seeing If I can Pump some more lifeblood into the Diying machine.
And now for some comical relief
Original
HP Microserver N54L
4 Gigs of ECC ram
Current
HP Microserver N54L
1x4 TB WD Red
![IfF5CMP.jpg](http://i.imgur.com/IfF5CMP.jpg)
