VladTepes
- May 18, 2016
The motherboard is an Asrock EP2C602-4L/D16 -
https://www.asrockrack.com/general/productdetail.asp?Model=EP2C602-4L/D16
128 gig quad ecc ram, dual intel xeon e5-2670 so 8 cores and 16 threads each (the motherboard can take most e5 v1 and v2 cpu's).
(The board can also be run on a single i7 cpu if necessary)
it has 4 onboard 1 gig nics which can be teamed + an additional dedicated ipmi port to make 5 1 gig nics.
Has onboard graphics as well Output- Supports D-Sub with max. resolution up to 1920x1200 @ 60Hz.
