Hi all, first time poster here.
Been down the NAS rabbit hole for a month now and still struggling to make the right decision, here's where I'm at:
Currently taking a workstation build to turn into a NAS server...
Specs:
Processors: (2) Intel® Xeon®E5-2670 2.60 GHz
Cooling: (2) Gamerstorm Captain 120ex Liquid CPU Cooler
Motherboard: ASRock EP2C602-4L/D16
Graphics Card: Nvidia GTX 980ti Hybrid
Memory: Hynix 8x8GB 240-Pin DDR3 SDRAM ECC Registered DDR3 1333 (PC3 10600) Server Memory Model HMT31GR7BFR4A-H9 (128gb)
SSD: Samsung 850 Evo 250gb
HDD: (5) Ironwolf Pro 16TB
HBA: Testing multiple cards including LSI 9211-8i
Power Supply: Cooler Master Silent Pro M1000 (1000w)
Case: Phanteks Enthoo Pro Series
ETH: MikroTik 5-Port Desktop Switch, 1 Gigabit Ethernet Port, 4 SFP+ 10Gbps Ports
NIC: 10Gb SFP+ PCI-E Network Card
So, 3 questions
1.) How are these specs for a NAS build? Intended for speed, redundancy, editing, rendering - is it overkill and better suited to keep as a workstation?
2.) Am I limited to windows server if I want the system to double as a workstation? Obviously a ZFS system is preferred to protect my data
3.) Can I achieve similar NAS goals using an older pc I have laying around that is not built with server components?
Specs:
Processor: Intel i7-930 Costa Rica 2.80 GHz
Motherboard: Gigabyte GA-X58A-UD3R
Memory: GSkill DDR3-1600 4Gx6 PC3-12800 (24gb)
Thanks in advance for your help, it's very much appreciated.
- I'm realizing that I can no longer use the computer as a workstation if I go the TrueNAS route - correct me if I'm wrong here.
- Main purpose of this build is to amalgamate all my data into one centralized storage center where I can have multiple editors working from at once.
Specs:
So, 3 questions
Specs:
