Advice on first build
shipser
We have had other users in England and Australia use this service to buy things in the US and have it shipped to them because, even with the additional shipping charge, they are sometimes less expensive and they can get things they wouldn't otherwise be able to get.
thanks, will check.
BDW, how do you add the nas button here on the forum?like in your signature?
Chris Moore
I tried to answer by posting the 'code' but it interpreted the code instead of displaying it...
The 'opening bracket' should be: [
and the 'closing bracket' should be: ]
opening bracket	SPOILER="Emily-NAS"	closing bracket
- - - put text here - - -
opening bracket	/SPOILER	 closing bracket
Inxsible
Use the spoiler tags on your signature page in your profile
[ SPOILER="FreeNAS box"] and end it with [/SPOILER ] without the spaces
Inxsible
Inxsible
@shipser I am surprised no one has mentioned this to you yet in this thread, but have you considered getting a X9 or X10 based board? It will save you a lot of money because DDR4 is super expensive currently and the slightly older generation equipment might also be easily sourced since you are located in Israel.
[PLAIN] tags are your friend, they keep XenForo from interpreting their contents.
Not entirely, it seems. Nested PLAIN tags get simplified down to a single set.
Jeff Armstrong
You can even install and setup FreeNAS via IPMI. I know I did.
Indeed, I wasn't clear about that :) I pulled out an old X9SCM board last night and went to my viewer and forgot my password so I ended up having to pull out an old monitor anyway and FreeDOS util it to reset the IPMI password -- bummer.
You can do it from FreeNAS, too.
shipser
thanks everyone.
i consider all your suggestions.
will post soon the end result, and the final part list.
