Hi All.
I know the Norco 4U stuff has been discussed before.
Unfortunately mine came with the 120mm fan plate.
As mentioned before, creating static pressure with 120mm fans is quite a bit harder than 80mm fans. Also, finding high quality 120mm fans with decent static pressure seems problematic.
Being that 80mm fans create pressure more easily, I think it would take less energy if I changed to 80mm fans. And 80mm fans of decent quality are far more easily found.
That being said, I can't seem to find a source for the 80mm fan bracket. I can find the 120mm one everywhere of course, which doesn't help.
Anybody have a source for one?
Thanks.
Thanks.
