- Aug 16, 2011
Building up a new FreeNAS machine using a SuperMicro MBD-X9SCL-F, current BIOS. Right now it has 2x WD Red 3 TB drives installed. However, one of them is showing up as 2 TB capacity, not 3 TB. This persists if I swap cables and motherboard SATA ports. SMART data for the apparently-defective drive follows:
Both drives were purchased new, and neither has been used in any other system other than having the SMART self-tests run while connected to a different system. I'm thinking the drive is defective and needs to be replaced--is there any other possibility I'm missing?
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red (AF)
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N0xxxxxx
LU WWN Device Id: 5 0014ee 20a0a55a4
Firmware Version: 80.00A80
User Capacity: 2,000,421,444,608 bytes [2.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat May 24 17:10:33 2014 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40380) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 405) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 179 179 021 Pre-fail Always - 6016
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 7
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 13
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 7
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 6
194 Temperature_Celsius 0x0022 120 114 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Conveyance offline Completed without error 00% 10 -
# 2 Extended offline Completed without error 00% 7 -
# 3 Short offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
