Confused about error: Device: /dev/ada3, 5 Currently unreadable (pending) sectors
Kortex
I've seen this error on the forums before. I also see what people have done to fix it. I examined the log but I don't see where the 5 bad sectors are?
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WMC4N0K57AP1
LU WWN Device Id: 5 0014ee 05957cad4
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Jul 9 18:56:28 2017 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40020) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 401) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 153 153 051 Pre-fail Always - 1131
3 Spin_Up_Time 0x0027 179 179 021 Pre-fail Always - 6041
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 21
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 430
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 21
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 13
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 75
194 Temperature_Celsius 0x0022 119 112 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 5
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 398 -
# 2 Short offline Completed without error 00% 318 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Stux
How old is your drive?
Last test was completed at 400hours.
If it's in warranty get it RMA'd
Kortex
Not very old at all. Do you see the problem :(?
I just got a
July 9, 2017, 7:26 p.m. - Device: /dev/ada3, Self-Test Log error count increased from 0 to 1.
Jul  9 19:52:40 freenas smartd[2650]: Device: /dev/ada3, 5 Currently unreadable (pending) sectors
Should I shut the server off? The drive has only 300 hours on it.
m0nkey_
I just got a
Time to replace the drive.
Kortex
Thank you both for your replies! Would you mind telling me exactly what tells you I need to replace it? Is it just the pending sectors or was it something in the log or both or? The more I understand the less I will post and bug you guys :D.
Stux
5 Pending sectors means five sectors couldn't be read. So far.
This is basically a broken disk, since it is failing to read data that was written within the last two weeks.
diedrichg
As mentioned, if it's still under warranty, RMA it.
If possible, try to return it to the vendor. If you RMA it to WD, you'll get a refurbished drive in exchange. If you return it to your vendor, you should get new.
On a drive that's been in service for a while, five pending sectors wouldn't greatly worry me, but this is a new drive. I'd replace it.
