ZFS Pool Corrupted, volume state is unknown.
di0de
I got an email alert saying: The volume myvolume (ZFS) state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
My ZFS pool is two WD Red's, 4TB RAID0. They are brand new (less than 1 week old). After installing them, I copied about 3TB of data via rsync. Last night I initiated a scrub on the volume.
After getting a warning I checked zpool status -v, here are the results:
 pool: myvolume
state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 5h16m with 1 errors on Mon Jan 18 02:53:08 2016
    NAME                                          STATE     READ WRITE CKSUM
    myvolume                                      ONLINE       1     0     0
      gptid/51c355c9-b4fd-11e5-81a4-6c0b843d5ce5  ONLINE       1     0     0
      gptid/52e8f263-b4fd-11e5-81a4-6c0b843d5ce5  ONLINE       0     0     0
errors: List of errors unavailable (insufficient privileges)
Unfortunately I didn't run as root so I didn't get the list of errors. Here is the output of smartctl -a /dev/ada0:
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68WT0N0
Serial Number:    WD-WCC4E3ZLH04A
LU WWN Device Id: 5 0014ee 2b760c63a
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Jan 18 11:43:11 2016 MST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (52380) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 524) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       277
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       23
194 Temperature_Celsius     0x0022   123   120   000    Old_age   Always       -       29
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
and for ada1:
Serial Number:    WD-WCC4E3HJX3N6
LU WWN Device Id: 5 0014ee 20cb6376f
Local Time is:    Mon Jan 18 11:44:26 2016 MST
                    was never started.
                    been run.
data collection:         (53760) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 537) minutes.
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       22
194 Temperature_Celsius     0x0022   122   119   000    Old_age   Always       -       30
No Errors Logged
I was reading up on another thread, where it was advised to run a memory test. I rebooted the system thinking it would be an option in the Grub menu, but it was not. After finishing the reboot, now the device state is unknown, zpool status doesn't not output the volume.
Fortunately my data is backed up on another disk, but right now its my only backup. Not sure what my next steps should be, I guess run that memtest? Does it seem like my disks are bad, or the memory? Or could it have been due to the rsync or scrub?
m0nkey_
I think you should put this as a lesson learned, a stripe (RAID0) is not exactly the best idea in the world especially if you have something important to store. Lose one drive in your current configuration and you lose your pool. I'd re-do your pool and create a mirror vdev.
di0de
Why is RAID0 bad if I am backing up to another pool? Do you think my disks are bad? I can RMA because they're brand new. The machine is under warranty too if you think the RAM is bad.
EDIT: I forgot to add, yesterday it was reported another drive state is unknown, this is connected via usb. I thought the plug was loose so I secured it, rebooted and the pool came back. I wonder if its related?
Sakuru
Your pool exploded and you have to ask why RAID0 is bad?
Bidule0hm
Server Electronics Sorcerer
You didn't burn-in your system (especially the drives) from what I can see. I guess one of the drive suffers from infant mortality (that's why you want to burn-in the system before putting any real data on it).
Run a long smart test on each drive and repost the output of smartctl -a after the tests are finished (about 10 hours, you can do both drives at the same time).
USB connected drive? that's a genuine very bad idea... there's nothing more unreliable than USB (excepted Realtek NICs maybe... :D)
m0nkey_
There's your problem. You have a stripe using a USB drive. Plug the drive in using a SATA connection at best.
di0de
Yes, I'm aware its a big no-no, in fact its the reason I spent money upgrading my system over the holidays :p
I'll run the smart tests and post the results, thank you!
di0de
I tried this, but the usb enclosure does some kind of hardware encoding on the disk, so I couldn't use it via SATA. My goal was to transfer the data to the two WD Reds, and then wipe the external drive, then use with the system via SATA. A temp solution that's now my only backup... :eek:
Mirfster
Except from Cyberjock's "Slideshow explaining VDev, zpool, ZIL and L2ARC for noobs!":
Using external disks (USB, Firewire, or eSATA) is not recommended.
External disks are prone to accidentally being unplugged by bumping the power or data cable. Plenty of users that swore they would be safe with their server in the basement where its locked and in a corner have still made mistakes and lost data.
Most external disks on a single error of any kind will disconnect and reconnect to the host. This will result in data loss and you may not get any warning that this is going on until it is too late.
USB and Firewire do not allow for proper read/write error detection.
USB and Firewire usually do not allow for proper SMART monitoring, reporting or testing. This removes one of your main methods for identifying disk problems early.
For these reasons, using a laptop is not a good option for FreeNAS because you will have to rely on external disks. They also usually use hardware that isn’t compatible with FreeBSD.
Plenty of users have lost significant amounts of data by using external disks despite these warnings. Don’t be a statistic!
Laptops also make poor choices because quite often the hardware is customized to the point where there are no FreeBSD drivers for the hardware, and you can’t just install a new network card or SATA controller. Even for testing they are pointless as they will not behave properly or effectively to give an accurate assessment of a FreeNAS system.
SweetAndLow
Sweet'NASty
umm.. this is why things are breaking. ZFS needs direct access to the disks. Stop using usb, stop using enclosures and stop using raid.
di0de
The USB drive is not relevant, unless you're saying it has a destructive effect on a totally separate zpool? Regardless, I am attempting to subtract the external drive from my configuration. It is the reason I bought all new equipment. Cyberjock's presentation, which I've read, shows examples of using RAID, so I'm confused as to why everyone is saying RAID is bad, don't use it.
I just ran short smart tests on the two WD reds, and they completed without error. I am running a long test now, I'll post results when they finish. Thanks again for the help, all.
gpsguy
Active Member
Noone's saying that.
You've striped the 2x4TB drives together, giving you ~8TB of storage, but no redundancy. If one disk fails, all your data is gone.
What's been suggested is to mirror them, which would give you ~4TB of storage. If one of the disk failed, data would still reside on the other disk.
Bidule0hm
I guess @SweetAndLow was talking about hardware RAID which is big no-no.
di0de
Ah, that makes sense, thanks for clearing it up. Well, one of my drives is definitely F'd. Test has been running for about 5 hours, but I have been notified of an error on one of the disks. Not good, guess I'll have to RMA that one.
ada0:
# 1  Extended offline      Completed: read failure       60%       281         3091315168
# 2  Conveyance offline  Completed without error       00%       278         -
# 3  Short offline       Completed without error       00%       278         -
Both tests are still running, but ada1 has 30% remaining, where the flagged disk, ada0 has 60% !
Bidule0hm
Yep, error on an extended test = RMA ;)
di0de
As of this morning there are 6 errors, oddly the test now says 90% left... its clear the drive is bad. I will RMA it, one more question though. I bought the two drives together, should I RMA them both? If its a bad batch, the other drive may have errors sooner than later. Then again the damage could have been caused by shipping, or handling somewhere along the line. The second drive shows no errors, here are its results of the smart test:
Model Family:     Western Digital Red (AF)
Local Time is:    Tue Jan 19 08:02:23 2016 MST
                    was never started.
Self-test execution status:      ( 241)    Self-test routine in progress...
                    10% of test remaining.
                    command.
                    power-saving mode.
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       297
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       26
194 Temperature_Celsius     0x0022   120   118   000    Old_age   Always       -       32
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
# 1  Extended offline    Completed without error       00%       288         -
and ada0, the BAD disk:
Local Time is:    Tue Jan 19 08:02:51 2016 MST
                    was never started.
Self-test execution status:      ( 249)    Self-test routine in progress...
                    90% of test remaining.
                    command.
                    power-saving mode.
194 Temperature_Celsius     0x0022   120   120   000    Old_age   Always       -       32
No Errors Logged
# 1  Extended offline    Completed: read failure       60%       296         3091315168
# 2  Extended offline    Completed: read failure       60%       293         3091315168
# 3  Extended offline    Completed: read failure       60%       290         3091315168
# 4  Extended offline    Completed: read failure       60%       287         3091315168
# 5  Extended offline    Completed: read failure       60%       285         3091315168
# 6  Extended offline    Completed: read failure       60%       281         3091315168
# 7  Conveyance offline  Completed without error       00%       278         -
# 8  Short offline       Completed without error       00%       278         -
Mirfster
Would be difficult to get an RMA on the second drive since it has no errors. IMO, if it passes the testing I would say keep it since it can be classified as a "known good" drive then. There may always be the chance that a new drive has "infant mortality" or could be damaged in shipping as well. P.S., it pays to have extra spare parts as well.
