Hey, about six months ago I bought 3 WD 3TB red and I want to know that everything is fine, and that I did not get a bad drive.
Everything works fine except slow writing speed in SMB (I'll open a post later in the appropriate place)
Thanks
Itay
These are S.M.A.R.T Tests:
Thanks
Itay
smartctl -a /dev/ada1Code:
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68N32N0
Serial Number: WD-WCC7K1FU80RF
LU WWN Device Id: 5 0014ee 20fbb11e3
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Jul 15 19:47:02 2019 IDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (31200) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 332) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 163 163 021 Pre-fail Always - 6850
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 19
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3220
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 19
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 3
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 18
194 Temperature_Celsius 0x0022 110 104 000 Old_age Always - 40
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 3218 -
# 2 Short offline Completed without error 00% 1981 -
# 3 Short offline Completed without error 00% 580 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.smartctl -a /dev/ada2Code:
Serial Number: WD-WCC7K1AZV1E4
LU WWN Device Id: 5 0014ee 20fbb4f62
Local Time is: Mon Jul 15 19:49:17 2019 IDT
was never started.
been run.
data collection: (33120) seconds.
command.
power-saving mode.
recommended polling time: ( 352) minutes.
3 Spin_Up_Time 0x0027 171 171 021 Pre-fail Always - 6441
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 19
No Errors Logged
# 1 Extended offline Completed without error 00% 3219 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.smartctl -a /dev/ada3Code:
Serial Number: WD-WCC7K2XZULKT
LU WWN Device Id: 5 0014ee 265019d0c
Local Time is: Mon Jul 15 19:50:25 2019 IDT
was never started.
been run.
data collection: (32520) seconds.
command.
power-saving mode.
recommended polling time: ( 346) minutes.
3 Spin_Up_Time 0x0027 166 166 021 Pre-fail Always - 6666
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 20
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
194 Temperature_Celsius 0x0022 111 107 000 Old_age Always - 39
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
