I followed https://doc.freenas.org/9.3/freenas_install.html#installation-troubleshooting and installed FreeNAS on a USB succesfully. However the USB with the FreeNAS installation doesn't show up as a bootable device on my Macbook(tested it on another Machine, didn't work either).
I'm not talking about the FreeNAS installer. I used and that worked fine.
I'm talking about the USB on which I installed FreeNAS using the FreeNAS installer.
USB types and size are exactly the same.
sudo dd if=FreeNAS-9.10.1.iso of=/dev/rdisk3 bs=64k
