UPS via USB... I think it's working?
shackrock
Ok so I have FreeNAS 8.3.1 STABLE (latest version).
I've set up my UPS, and I've found that it's on port /dev/ugen1.1 -> I know this because I turn the service on and can successfully type "upsc ups@localhost" and it spits out a bunch of info. So, I shut down the computer, and start it back up (unrelated reason) - and now when I run that command it says "Error: Data stale"
hmmmm
So, I stop the service in the GUI, and start it again, and now I see all the data again!
[root@freenas] ~# upsc ups@localhost
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 20
battery.mfr.date: CPS
battery.runtime: 2760
battery.runtime.low: 300
battery.type: PbAcid
battery.voltage: 8.7
battery.voltage.nominal: 12
device.mfr: CPS
device.model: CP685AVRLCD-G
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: /dev/ugen1.1
driver.version: 2.6.5
driver.version.data: CyberPower HID 0.3
driver.version.internal: 0.37
input.transfer.high: 140
input.transfer.low: 90
input.voltage: 121.0
input.voltage.nominal: 120
output.voltage: 121.0
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.load: 21
ups.mfr: CPS
ups.model: CP685AVRLCD-G
ups.productid: 0501
ups.realpower.nominal: 390
ups.status: OL
ups.test.result: Done and passed
ups.timer.shutdown: -60
ups.timer.start: 0
ups.vendorid: 0764
So.... why doesn't it work on first boot, will I need to always stop and start the service every time I restart the server (i.e. after a power outage...)?
update - ok already I've gotten this message on the console:
Broadcast Message from root@freenas.local
        (no tty) at 18:17 EDT...
Communications with UPS ups lost
and I continue to get this over and over....:
Apr  3 18:18:53 freenas kernel: ugen1.3: <CPS> at usbus1 (disconnected)
Apr  3 18:18:55 freenas upsmon[3825]: Poll UPS [ups] failed - Data stale
Apr  3 18:18:56 freenas kernel: ugen1.3: <CPS> at usbus1
Apr  3 18:19:00 freenas upsmon[3825]: Poll UPS [ups] failed - Data stale
Apr  3 18:19:03 freenas kernel: ugen1.3: <CPS> at usbus1 (disconnected)
Apr  3 18:19:05 freenas upsmon[3825]: Poll UPS [ups] failed - Data stale
Apr  3 18:19:05 freenas kernel: ugen1.3: <CPS> at usbus1
Apr  3 18:19:10 freenas upsmon[3825]: Poll UPS [ups] failed - Data stale
Apr  3 18:19:13 freenas kernel: ugen1.3: <CPS> at usbus1 (disconnected)
Apr  3 18:19:15 freenas upsmon[3825]: Poll UPS [ups] failed - Data stale
Apr  3 18:19:15 freenas kernel: ugen1.3: <CPS> at usbus1
Also, is there a way I can really test to see if it's working together? Is it simply to shut off the breaker, or is there a software-related test I can do to find out?
Thanks!
ProtoSD
Thanks!
I've seen several other posts from people complaining of the same problem but it still seems to work. I don't notice it happening on mine.
The way to test it is just to unplug your UPS and see if the email warning gets sent. Don't forget to have your router and modem connected to the UPS also, or if they lose power the message won't be able to be sent.
shackrock
Well what's even more weird, is that the messages that continue forever and ever on the console reference the wrong "port"
ugen1.3
- but I'm plugged into (and the plugin is set to)
/dev/ugen1.1
.... that doesn't make any sense does it?
paleoN
Actually it does. The usbhid-ups driver for most, possibly all, sub-drivers queries the USB ports for the UPS. I specified auto for the port value for my UPS and it works just fine.
- - - Updated - - -
ugen1.3
Have you tried a different USB 2.0 port?
shackrock
Ah HA! That's the fix. I did not know that you could type anything into the port field, I thought I had to select from the list (and auto is not an options). I have now typed auto in there and started the service, and everything seems perfect! Awesome.
Let me ask, is it possible to make the server restart when power has been restored for X seconds?
paleoN
shackrock
Did not test a reboot yet, I'll do that this weekend though.
Right now, I think I'm just shutting down FreeNAS when power is lost (After a delay of like 2 minutes). I'd like to also start FreeNAS back up (power up the PC again) once power is restored for X minutes.
I don't believe you can set it to power back up automatically with the UPS service. Once the server shuts down, the only 3 ways I know of to turn it back on is Wake-On-LAN, pressing the power button, and if your BIOS supports the power on at a particular time(but this doesn't help you for restoring from a loss of power).
paleoN
Easily configured via the GUI.
This would be a function of the actual UPS. On non-broken UPS hardware, the UPS will wait until the battery charge is no longer critical before turning the load back on. However, this is considered a feature and most consumer UPS are sold as cheaply as possible.
anika200
This would imply some sort of intelligence on the part of the UPS that just does not exist yet.
